Dana 36?
Old Feb 19, 2004 | 06:50 PM
JAPARR's Avatar
JAPARR
8th Gear
Default Dana 36?
Will a 36 from an 89 fit an 84 (automatic)?
Old Feb 19, 2004 | 07:28 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Dana 36? (JAPARR)
A 36 from any C4 will fit any other C4. If it is replacing a 36, there are no conversion considerations. Good luck, and...
RACE ON!!!
Old Feb 19, 2004 | 07:34 PM
Pete K's Avatar
Pete K
Default Re: Dana 36? (CFI-EFI)
The 4 thru bolts yhat hold strut brackets to bottom corners of rear are larger on the 89. Yiu will need the larger diameter bolts or the brackets will twist while driving. Just thought you might need to know. :D
Old Feb 19, 2004 | 07:44 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Dana 36? (Pete K)
Good to know. Thanks.
RACE ON!!!
To Dana 36?
