Wire help on ZF6...
Old Feb 19, 2004 | 10:02 PM
byte_me's Avatar
byte_me
Default Wire help on ZF6...
OK...I am swapping my 4+3 to a ZF6 and not sure what wires go where???
I see a plug on the tail shaft? one on the side attached to a metal barrel looking thing?? and one towards the front??
What goes where???
Thanks!
Old Feb 20, 2004 | 08:17 AM
vetteoz's Avatar
vetteoz
Default Re: Wire help on ZF6... (byte_me)
One on the tailshaft is speedo drive , the solenoid on LH side is the CAGS(DELETE IT) and up front LH side is the reverse light switch.
From memory the speedo plugs straight in but you will probably have to change the gears in the tailshaft to suit your current setup .ZF6s came with 3.33 or 3.45 ratios where as 4+3 were 3.07
Old Feb 20, 2004 | 10:10 AM
byte_me's Avatar
byte_me
Default Re: Wire help on ZF6... (vetteoz)
Thanks!
When you say delete it- you mean just don't try to connect anything to it correct???
Cheers....
Old Feb 20, 2004 | 10:14 AM
bogus's Avatar
bogus
Thanks!
Cheers....
:yesnod:
that's right. CAGS was designed to help sneak the manual vettes through EPA tests for mileage. it's a waste... Computer Aided Gear Shifting.
Old Feb 20, 2004 | 12:25 PM
byte_me's Avatar
byte_me
Default Re: Wire help on ZF6... (bogus)
Thanks guys! always a pleasue getting info on here! :cheers:
To Wire help on ZF6...
