spark advance
Old Feb 19, 2004 | 10:20 PM
6spd's Avatar
6spd
Default spark advance
i have a 91 vette and i was wondering if you can check spark advance at idle. the streets here are sandy so i don't want to drive it. i do have the e-z link scanner and at idle it was jumping from 17-21 back and forth is there a better way to see if it's right in the garage.????
Old Feb 20, 2004 | 07:50 PM
jfb's Avatar
jfb
Default Re: spark advance (6spd)
Shine your timing light on the vibration damper and read the advance from the timing plate and the line on the damper. But.... don't do this in your garage, back the car out so you don't get carbon monoxide exposure. Read your service manual about setting the initial timing which is done at idle.
