Instrument Lights
Old Feb 20, 2004 | 01:39 PM
Al Goodwin's Avatar
Al Goodwin
Default Instrument Lights
If I turn my lights on during the daytime, the insrtument cluster lights work. If I turn the lights on at night, The instrument lights do not come on. This makes me believe the light switch is notthe problem. Any ideas. Thanks.
Old Feb 20, 2004 | 02:45 PM
bogus's Avatar
bogus
Default Re: Instrument Lights (Al Goodwin)
the only thing I can figure is the photocell is bad...
Old Feb 20, 2004 | 07:40 PM
jfb's Avatar
jfb
At night the lights are dimmed. First try rotating the headlight **** counterclockwise which increases the brightness. If this doesn't do it and all 4 lamps are lit, then you have a problem with the dimming circuit which is on one of the two circuit boards in the cluster.
To Instrument Lights
