86 Horn Button
Old Feb 20, 2004 | 02:26 PM
goodson's Avatar
goodson
Default 86 Horn Button
Having problem with horns not working and think it may be in the button. Is the button removal as simple as it sounds - pry it off with a screw driver?
Old Feb 20, 2004 | 06:25 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: 86 Horn Button (goodson)
Its even simpler to remove. Just grap with finger tips and pull it off. There is one wire connected to button. Disconnect it from the button, make sure the other end is properly plugged into the column. The sockets break often. Its a springloaded twist in connector. If that is connected properly, ground other end (the end from the button) against the steering wheel retainig nut. If the horn blows it will confirm your suspicion.
Old Feb 21, 2004 | 01:57 PM
goodson's Avatar
goodson
Default Re: 86 Horn Button (blk90rdstr)
Thanks for the info. The problem is with the horn button. Now, another question, is the horn button a self-contained unit? or can it be accessed and repaired by taking the rubber housing off?
Old Feb 21, 2004 | 11:58 PM
goodson's Avatar
goodson
I got the button apart only to discover that the problem was in the spring contacts in the steering wheel. Bent them back in place and horn works fine now - Thanks!
To 86 Horn Button
