How do you know....?
Old Feb 20, 2004 | 07:03 PM
MPforUSMC's Avatar
MPforUSMC
Default How do you know....?
How do you know when your stall converter is going bad? Here is the problem: When I slam on the gas at highway speeds, something grinds {tranny? stall converter?}and the gear wont catch until i let off the gas and apply less throttle. Any suggestions?
THanks!
Old Feb 21, 2004 | 06:15 AM
C10 JDR's Avatar
C10 JDR
Default Re: How do you know....? (MPforUSMC)
Simple things first, check your fluid level.
Old Feb 21, 2004 | 10:54 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
:iagree:
You might also reset the TV cable though it mostly controls part-throttle shifts.
But noise from the A4 isn't a good sign; good luck.
Old Feb 21, 2004 | 12:34 PM
MPforUSMC's Avatar
MPforUSMC
Default Re: How do you know....? (65Z01)
Thanks guys...is this something a shop can accurately check and diagnos?
Old Feb 21, 2004 | 02:42 PM
86Moon's Avatar
86Moon
It would sure be best to get it to someone who really KNOWS vette trannys :seeya
To How do you know....?
