Go to this page then scroll way down to the XE cams made for factory roller cars. These cams will not fit the LT-1/4 cars with out the pin in the front of the cam which I"m sure they can do. the 224/230 cam looks good as well if it had just a little more lift with 1.6 rockers it would be nice.
Gross Valve Lift: 510 I 520E 1.5RR
Installed at 108 Intake Centerline
Duration at .050 230 I 236 E
Lobe Lift .3400 I 3470E
Lobe Seperation 112
Valve timing at .050 open int 7 BTDC
exh 54 BBOC
close 43 ABDC
2 ATOC
Duration at .006 Tappet Lift 281 I 288 exh
