C4 Quarter Mile Times
Old Feb 21, 2004 | 07:03 PM
95VetteRed's Avatar
95VetteRed
Cruising
Default C4 Quarter Mile Times
I was just looking to get an idea on what my quarter mile times would be.
My mods are below also its an auto. I just wanted to get an Idea of what my times would be. I heard auto C4's LT1's run 13.8's and Manuals 13.6's??? Correct me if I'm wrong
Old Feb 21, 2004 | 07:11 PM
JackDidley's Avatar
JackDidley
Default Re: C4 Quarter Mile Times (95VetteRed)
If I dont ask someone else will. How do you bore heads out to 6.0?? :skep: :skep:
Old Feb 21, 2004 | 07:30 PM
Knight Ryder's Avatar
Knight Ryder
St. Jude Donor '05-'06-'07-'08
If it helps, my LT4 did 13.3 @ 107. I'm hoping I can get 12s with a better launch. :steering:
It's hard to say because conditions always change. I've gone as slow as 14.0. I'm sure someone can give you a better idea, but I would guess somewhere right around 13.0 or a few ticks quicker?... :seeya
[Modified by Knight Ryder, 7:31 PM 2/21/2004]
Old Feb 21, 2004 | 07:33 PM
vader86's Avatar
vader86
Default Re: C4 Quarter Mile Times (Knight Ryder)
Anywhere in the mid 13s stock.
There are those here with no mods running just above 13 flat with auto and manual.
Old Feb 21, 2004 | 07:39 PM
LT4BUD's Avatar
LT4BUD
420 Horsepower should put you mid 12's or better depending on what rear end gears, torque converter, tires etc
Old Feb 21, 2004 | 08:04 PM
marlon88's Avatar
marlon88
Default Re: C4 Quarter Mile Times (Spankyellow)
Sory but I have to correct you on this one .
He said that he bored out Cylinders Not Cylinder heads , he bored out the cylinders of the block from 4.000" to a 4.030" bore . So from 350ci it became 355ci some where near 5.8L .
With the Mods listed in the signiture and some good tires/traction you will be high 12`s .
Old Feb 21, 2004 | 08:05 PM
95VetteRed's Avatar
95VetteRed
Cruising
What rear end do you guys suggest?
Old Feb 21, 2004 | 08:08 PM
marlon88's Avatar
marlon88
3.73:1 is the best I think for an LT-1 auto .
Old Feb 21, 2004 | 08:09 PM
JackDidley's Avatar
JackDidley
Default Re: C4 Quarter Mile Times (marlon88)
Must have been an edit. When I read it it saaid heads bored to 6.0L.
Swear to God!!
Old Feb 21, 2004 | 08:19 PM
marlon88's Avatar
marlon88
Swear to God!!
Sorry then I appologise :grouphug:
Old Feb 21, 2004 | 08:23 PM
JackDidley's Avatar
JackDidley
cool!!! :cheers:
Old Feb 21, 2004 | 08:54 PM
vader86's Avatar
vader86
3.73 for the LT1 automatic with this combo, if you want the best possible times.
Old Feb 21, 2004 | 09:07 PM
wildman738's Avatar
wildman738
Default Re: C4 Quarter Mile Times (vader86)
mine has been at the track 3 times i'm all stock and have a 95 vert 3.07s, auto my best has been 13.3 this took a few learning tries to get that number i'm guessing your first run would be a 13.6ish.
Old Feb 21, 2004 | 09:10 PM
DieL's Avatar
DieL
Default Re: C4 Quarter Mile Times (wildman738)
id guess 12.8-13.3 at about 109-111 mph.. depends on how serious of a cam u went with though. if you slapped a 3.73 youll be flying.
Old Feb 22, 2004 | 02:01 AM
wildman738's Avatar
wildman738
Default Re: C4 Quarter Mile Times (DieL)
hey sorry about my other post i thought you was stock until now sorry.
Old Feb 22, 2004 | 02:10 AM
95VetteRed's Avatar
95VetteRed
Cruising
So 3.73's???? Any suggestions on where to get these? Ecklers? So with the 3.73's and I have Yokahama Tires on ZR-1 Rims I will get some pics soon, but what will the 1/4 time be with the 3.73's 12.5?
Old Feb 22, 2004 | 04:24 AM
DieL's Avatar
DieL
3.73s can make all the difference in the world. If you have a more aggressive cam that makes more top end power gears will really help the motor in the bottom-mid range. Again depending on how serious your heads and cam are 12.5s should be easy. With a 4.09 gear, 1.6 rrs, a chip k&n, headers with stock exhaust (without cats) and March pulleys i ran 12.7s @ 109 mph. Thats a stock motor (non ported never apart - internally stock). You should have a better cam, did you port your heads? - a better exhaust etc.. you could easily be faster. Even though its an auto you will launch easier and you dont have to worry about gears so your times will be consistant.
Personal advice would be dont shoot for a time. Most people have this idea that their cars are so fast and when they get to the track all they do is make excuses for themselves... oh the filter is dirty.. oh the sparkplugs need changing... it needs a tune up- etc etc. there are many other variables that come into play like weight (of driver too- Ive seen a 380 lb guy in a c4), altitude, temperature/humidity... etc etc.
Old Feb 22, 2004 | 01:47 PM
95VetteRed's Avatar
95VetteRed
Cruising
thanks for all the help guys!!! I will try to get pics up soon
To C4 Quarter Mile Times
