Vented the Opti today.
Old Feb 22, 2004 | 12:06 AM
C4Crazy787's Avatar
C4Crazy787
Default Vented the Opti today.
Upgraded my Opti-spark as-per the Corvette Fever Tip http://www.corvettefever.com/howto/16758 using the GM vacuum harness # 12558921.
The toughest part was getting the plastic "Y" sealed up to the plastic Opti cap, the 10$ soldering iron I bought got a workout. I wanted to make sure it was sealed, so holding my finger over the end of the "Y" I would fill the cap up with water, finally after about 6 tries I got it to hold water, no drips :hurray: .
This Opti has about 9k miles on it and the seal was already cracked at the bottom :banghead: , so I replaced them with (sensor safe) RTV.
Here are a couple of pictures of the finished product. http://www.digitalcorvettes.com/phot...optivent01.JPG
http://www.digitalcorvettes.com/phot...optivent02.JPG
I also got some other stuff done to, oil pan, timing cover, chain and gears, all of the exhaust system and the starter removed.
Oh yea, :eek:Surprise # 1 it seems as though I have a bad valve stem seal on # 1 exhaust, I noticed the port was all oily after I removed the manifold. All the rest of the ports are dry.
Replacing it should be no problem as I got pretty good at it when the LT4 springs went on. :thumbs:
[Modified by C4Crazy787, 10:33 AM 2/22/2004]
Old Feb 22, 2004 | 12:29 AM
bogus's Avatar
bogus
Default Re: Vented the Opti today. (C4Crazy787)
busy day! But think of all the money you saved! :thumbs:
That's great!
When I vented mine, I used Epoxy. Seemed to seal very nicely.
Old Feb 22, 2004 | 04:33 AM
DieL's Avatar
DieL
Default Re: Vented the Opti today. (bogus)
I actually forgot to check the vacuum lines on mine. I upgraded to a 95 style but dont know where to hook up the vaccum lines... where to ??????
Old Feb 22, 2004 | 04:58 AM
BowTieBlood's Avatar
BowTieBlood
:smash: Working hard :eek:
Old Feb 22, 2004 | 10:24 AM
C4Crazy787's Avatar
C4Crazy787
Default Re: Vented the Opti today. (DieL)
Check out the pictures in this thread. http://forums.corvetteforum.com/zerothread?id=758749
Also check this Corvette Fever Tip http://www.corvettefever.com/howto/16758
:seeya
To Vented the Opti today.
