mirror image -56cc pistons
Old Feb 22, 2004 | 09:06 AM
streetbad's Avatar
streetbad
6th Gear
Default mirror image -56cc pistons
How high can the wrist pin be with a lt1 mirror image of the combustion chamber in the piston(for high boost integrity)? I need to order a crank and I'm stumped on how much stroke I can have. Thanks -Tim
Old Feb 22, 2004 | 07:56 PM
JordonMusser's Avatar
JordonMusser
Default Re: mirror image -56cc pistons (streetbad)
56! YIKES. i would HIGHLY reccomend a bigger chamber head/less dish. I dont even think you can a piston that big
Old Feb 23, 2004 | 10:09 AM
Baldturbofreak's Avatar
Baldturbofreak
Your best bet is to make a mold of your chamber (after it has been significantly milled to get at least some comp. and measure the thickness. subtract that from your comp. height (distance from centerline of wristpin to deck of piston. stock=1.560") and see whats left.
I like the direction your taking, small chamber and big rev dome. It could help direct more cylinder pressure at the piston. But a neg 56 is alot! unless you have 40cc nascar heads! :chevy
Old Feb 23, 2004 | 01:16 PM
SloRvette's Avatar
SloRvette
Cruise-In VII Veteran
Default Re: mirror image -56cc pistons (Baldturbofreak)
Try calling Diamond. I know they've done Buick dished pistons that copy combustion chamber shape. The numbers .150" to .250" at thinest portion of the piston face are popping into my head. .150" on a normally aspirated or small nitrous piston and .200" to .250" with a high output piston.
I'm in the same boat. I'm going to need a set of pistons to go with a 38 cc chamber for around 9 to 9.5 to 1 compression, with as tight a quench area as possible.
To mirror image -56cc pistons
