I am looking for some high quality stud fasteners for my aluminum AFR heads. I don't like the factory solution of bolting headers to aluminum heads.
Can anyone recommend a source? L98 TIA
Keep in mind you can't install the heads with the rear studs in place. You'll either have to put the heads on then put the studs in or just use some bolts in the rear.
Well, you can go the typical grade 8 bolts with locking nuts
or you can just use normal bolt (i have a set i'm not using i beleive, IM me) and use some good gaskets. Most guys run the Felpros and just tighten till there is no tomorrow. :cheers:
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
Re: Quality Head to Header studs (TreyZ28)
Bolts and locking nuts to install headers?? :lolg:
or you can just use normal bolt (i have a set i'm not using i beleive, IM me) and use some good gaskets. Most guys run the Felpros and just tighten till there is no tomorrow. :cheers: Bolts and locking nuts to install headers?? :lolg:
locking washers :bb :bb :bb
hreaded fasteners such as nuts & bolts can loosen when subjected to heat or vibration. To prevent this, bolts must be regularly retightened. Besides being unnecessarily time consuming, it can be damaging because it can lead to over-torquing. For this reason, Stage 8 locking fasteners has created a simple system that uses patented Groovelock Technology for keeping nuts & bolts tight without over-torquing.
Yeah, but those aren't "lock washers" in fact I have the stage eights to install my EM headers. Tell ya what, you just keep on using lock washers on your headers :lolg:
hreaded fasteners such as nuts & bolts can loosen when subjected to heat or vibration. To prevent this, bolts must be regularly retightened. Besides being unnecessarily time consuming, it can be damaging because it can lead to over-torquing. For this reason, Stage 8 locking fasteners has created a simple system that uses patented Groovelock Technology for keeping nuts & bolts tight without over-torquing. Yeah, but those aren't "lock washers" in fact I have the stage eights to install my EM headers. Tell ya what, you just keep on using lock washers on your headers :lolg:
