Oil level sensor question
Old Feb 23, 2004 | 08:45 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Oil level sensor question
Will eliminating the oil level sensor cause a 95 LT1 to throw a code?
Old Feb 24, 2004 | 10:33 AM
bogus's Avatar
bogus
Default Re: Oil level sensor question (Corvette Kid NC)
no, but you will get the low level warning light on your dash.
and with the propensity these motors have to leak, I would consider keeping the level working.
Old Feb 24, 2004 | 12:27 PM
c4cruiser's Avatar
c4cruiser
Why are you removing the sensor :confused: Are you going to use a different pan or is the sensor bad?
Like bogus mentioned, the LT1 motors are prone to leaks and removing it will only turn the Low Oil light on in the DIC.
To Oil level sensor question
