Oil Question
Old Feb 23, 2004 | 10:29 PM
VettBrat's Avatar
VettBrat
Default Oil Question
I have an '86 that just turned 90,000 miles. My oil pressure is okay. It runs 58-61 on the highway, but after it gets warm at idle the pressure drops to around 25, which is probably okay. I just bought the car in October and the owner said he always used 5w-30 oil. I live in Tulsa where the temps go over 100 in the summer pretty regularly. Do you think I would be better off using a 10w-30 oil? Or do you think it matters?
Old Feb 23, 2004 | 10:30 PM
bogus's Avatar
bogus
Default Re: Oil Question (VettBrat)
hm. That's a good question.
I would use 5-30, but switch to Mobil 1. It will handle the heat better than any dino oil.
Old Feb 23, 2004 | 10:34 PM
VettBrat's Avatar
VettBrat
Default Re: Oil Question (bogus)
After reading all the posts about synthetic oil causing leaks I am afraid of going that route. I am considering a blend though.
Old Feb 23, 2004 | 10:37 PM
wildman738's Avatar
wildman738
i would stick to factory fill 5w30 mobile 1 but the manual say 10w30 for certain temps..as for oil pressure when mine starts up ofcourse it's high 60+ some but after i do some crusin when i'm at the light with it in drive i get aroudn 35...so i think 25 sounds within range :thumbs:
Old Feb 23, 2004 | 10:40 PM
bogus's Avatar
bogus
Synthetic does not cause leaks... it simply finds the leaks that are there.
Believe me, you have a SBC and it WILL leak. Just get used to that idea...
Old Feb 23, 2004 | 10:53 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Just an FYI.
I have a '84 with 88k on it now. I use Valvoline Max Life Oil. Even cured my small oil leaks. Until you rebuild the motor stick with the same. I know what everyone else says. But believe me, and save yourself problems.
Been running on regular motor oil. Then stick with it.
tony
:steering:
To Oil Question
