96 Roadmaster LT1, need some info on this engine.
Old Feb 24, 2004 | 02:10 AM
Sting Raycin's Avatar
Sting Raycin
Default 96 Roadmaster LT1, need some info on this engine.
Hello from the C3 forum,
I have a chance to buy a 96 Buick Roadmaster Limited with the 5.7L LT1 and auto tranny. It has minor front-end damage from a wreck. I am interested in using the engine and tranny in a transplant. I just need to find out a little more about this particular LT1. I posted in the F-body forum, but there's not much activity there.
The engine appears identical to the one in the Impala SS. Is this the same as a f-body LT1 with the exception of the air intake, or are there other differences? Anybody know of anything that is undesirable about this engine or is it the same as the Camaro and firebird ones?
What kind of value does this engine and tranny combo have. I am trying to get a feel for what a good deal for the car would be.
I did check to make sure the 8th vin digit was a P.
Thanks for any info you can give me.
Old Feb 24, 2004 | 02:22 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: 96 Roadmaster LT1, need some info on this engine. (Sting Raycin)
Im not 100% sure since its been some years since I worked at a Buick Dealer but I do know the LT1 in the caddys and buicks were another version of the LT1 found in the F cars and Corvettes.They had cast iron heads instead of the performance alloy heads found in the sports cars.
Heres a site that may help you or give you more info.
http://www.hpsalvage.com/lt1.htm
Sorry I cant answer your questions further.
Old Feb 24, 2004 | 02:29 AM
Sting Raycin
Default Re: 96 Roadmaster LT1, need some info on this engine. (Bill's86Coupe)
Thanks for the link Bill's86
According to that it is has cast heads and 2 bolt mains.
Anybody take a guess as to a price for this set-up?
Old Feb 24, 2004 | 08:06 AM
HammerDown's Avatar
HammerDown
Tons of info here
http://www.impalassforum.com
I've got a '96 LT1 Caprice :thumbs:
Old Feb 24, 2004 | 08:24 AM
silver & red CE's Avatar
silver & red CE
...Anybody take a guess as to a price for this set-up?
It's no big deal. GM made over 75K iron headed LT1s a year from 94-96. As stated above, they're in most of the b-bodies and the caddy, there's also a baby LT1, the L99, it's a 265 ci version of the LT1.
edit: It's the same basic engine as the aluminum headed LT1, the only difference is:
Cam
Valve springs
actual head casting (same basic shape, the intake runners are SLIGHTY better than the aluminum heads because they came later).
That's it. With new cam/springs (ZZ4 or CC304 are a good ones for an auto trans) and headers you'll make over 300HP and 380 ft*lbs.
As for price...I'd guess less than $1,000 for the engine, less than $1,500 with the trans. Be sure to get the PCM too, you can get aftermarket wiring harnesses from someone like Howell.
Eric
[Modified by silver & red CE, 7:40 AM 2/24/2004]
Old Feb 24, 2004 | 08:37 AM
FD2BLK's Avatar
FD2BLK
The B body LT1s are good motors and the iron heads actualy flow better then the alum heads. almost forgot the W/P is also a bit diferent, they have a pully bracket on the front but other then the cast iron heads and the W/P they are the same as the F-body's (Corvette is the only 4 bolt main LT1)
[Modified by 84LT1, 8:43 PM 2/24/2004]
Old Feb 24, 2004 | 09:37 PM
DieL's Avatar
DieL
Default Re: 96 Roadmaster LT1, need some info on this engine. (84LT1)
i love that roadmaster!!! dont scrap it fix it!! drop an Lt4 in it, slam it with some 19s and uve got an AWESOME car!!
Old Feb 24, 2004 | 09:45 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: 96 Roadmaster LT1, need some info on this engine. (DieL)
Umm... I see how it is useful as a donor car for the engine/trans but can't see the appeal of the Roadwhale itself. :jester
[Modified by Lone Ranger, 8:45 PM 2/24/2004]
To 96 Roadmaster LT1, need some info on this engine.
