Normal Operating Temperature
Old Feb 24, 2004 | 10:25 AM
Pioneer's Avatar
Pioneer
Default Normal Operating Temperature
Although my 94 is not "over heating", it seems to run hot, between 250 and 255 degrees. Is this near the normal operating temp when standing still or in heavy traffic? Your replies are appreciated.
Old Feb 24, 2004 | 10:31 AM
vader86's Avatar
vader86
Default Re: Normal Operating Temperature (Pioneer)
250-255 is 'hot' for aluminum heads.
Check to see if your thermostat is sticking, the temps should stop rising at 180 for a while.
Clean the space between your radiator and condensor, the only way to do it is to remove the radiator shroud.
Flush the radiator and refill.
Check to see if the fans are working, the main fan should come on at about 228F. If they dont work, check the relays that are beside the shroud.
If all that doesnt work you either have a water pump problem or something more serious.
Old Feb 24, 2004 | 10:32 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
You talking about coolent or Oil temp? Both of those seem a little high for either. If its coolent change it. I am amazed how many Vettes have the original coolent still in them. :yesnod:
Old Feb 24, 2004 | 10:36 AM
Pioneer's Avatar
Pioneer
Default Re: Normal Operating Temperature (VictorRussell'92)
It is the coolent temp. Oil temp is ok. I appreciate the comments. I thought that these temps were not normal, and I can only imagine when this Atlanta weather reaches the muggy 90's this summer. :eek:
Old Feb 24, 2004 | 12:07 PM
darkman5001's Avatar
darkman5001
Have you seen any signs of a coolant leak at all? Check all hoses and check coolant strength. Also, make sure them fans are working. That seems very hot to me, and I am sure with the block and heads being that hot, that your oil temp is probably a little bit hotter than normal too. Hope you find the porblem soon. Summer is just around the corner.
:cheers:
Old Feb 24, 2004 | 12:09 PM
vvv90's Avatar
vvv90
Default Re: Normal Operating Temperature (darkman5001)
240 is about the hottest you should see in 100 degree weather in traffic.
Old Feb 24, 2004 | 02:17 PM
Pioneer's Avatar
Pioneer
Default Re: Normal Operating Temperature (vvv90)
I am being told that it is simply the water pump. Could it be that simple? Being simply a Vet lover and not a mechanic, I figured my buds on the board will know.
Old Feb 24, 2004 | 02:47 PM
CFI-EFI's Avatar
CFI-EFI
NO ! The only thing that is "simple" is the suggester. When the belt turns the pulley, the pulley turns the shaft. When the shaft turns, the impeller turns. When the impeller turns, it pumps water. Water pumps do not degrade. They fail and/or they leak. Good luck, and...
RACE ON!!!
Old Feb 24, 2004 | 02:49 PM
vader86's Avatar
vader86
Not quite. Do the other stuff first, unless you see coolant coming from the weephole on your water pump.
In which case, you must replace the WP IMMEDIATELY, or else you risk blowing your Optispark and doubling the cost of this repair.
Old Feb 24, 2004 | 02:57 PM
vvv90's Avatar
vvv90
Default Re: Normal Operating Temperature (CFI-EFI)
He's got an LT1.
Is it leaking coolant or making any grinding noises at the front of the engine?
Old Feb 25, 2004 | 12:32 PM
rick lambert's Avatar
rick lambert
To Hot, are your fan(s) comming on?and at what temp (could be a fan relay problem), your system might need burping! (could be air in the system),Yes by all means check for debris, they really do get trashed, you might want to check some of the thermostat threads on the forum-this is one of the major complaints on the forum, lots of good info. :rolleyes: :chill:
Old Feb 25, 2004 | 01:20 PM
SunCr's Avatar
SunCr
'94 fan control is from the a/c pressure switch - which turns on both fans and will cycle them on and off somewhere in a range of 230 psi on/170 psi off - or the coolant temp sensor if the a/c is off. If it's off, primary fan comes on at 219 and switches off at 208; secondary fan is commanded on at 228 and off at 217, so if it's at 250, both fans should be cranking which you can probably verify in your driveway. On the other hand, if you're relying on the gauge, you might want to scan it to determine what the coolant temp sensor and pressure switch are showing before you start replacing anything.
Old Mar 1, 2004 | 07:04 AM
Pioneer's Avatar
Pioneer
Default Re: Normal Operating Temperature (SunCr)
Just a TAD frustrated here :mad I appreciate all of the advise. I have printed them out for the obvious lane-brain that will be working on the LT1 this week. I suppose the saving grace is that it's not costing anything at this point since I'm within the 30 day CarMax grace period.
According to them, the water pump was replaced last week and it runs great. However, after driving for a while and coming to a stop behind this stupid Atlanta traffic, it approaches and maintaines 250 degrees until I start back up.
I agree! Even with my limited knowledge, I was thinking it's the fans as well. Lord help me before I loose my religion. Maybe your suggestions will enlighten this elementary school mechanic. :reddevil
Old Mar 1, 2004 | 07:32 AM
sofne89's Avatar
sofne89
Check your compression--could be a blown head gasket.Vettes are well known for that.250-255 is to hot. :eek: Good Luck :yesnod:
To Normal Operating Temperature
