CROSSFIRE OWNERS - Got some questions...
Old Feb 26, 2004 | 07:33 AM
Omega1's Avatar
Omega1
Default CROSSFIRE OWNERS - Got some questions...
Alrighty. 84 crossfire, GM 255HP crate topped with original crossfire injection. 700R4 and Dana 36 rear with *i think* 3.08's...
Looking to finally do a few small mods to her since i won't be able to finance the big block project till i'm on more solid financial footing. I was thinking of starting out with the X-Ram intake and going with a small (75-100hp) plate nitrous setup. Possibly doing a cam or 1.6RR but i don't wanna do anything that would require computer mods. Right now the exhaust is stock with no cat or mufflers.
what is your opinion of the X-Ram, and how much did you gain from it? i read over on crossfire injection forum that 25hp isn't unrealistic at all. and if you're running a plate kit, which one to clear the hood? i'm just not sure how much leeway there is under there...Also, how big of a cam could i get without really having to do computer work? the X-Ram is supposed to allow it to breath well up to as far as i'd like to spin it (proly 6k...don't wanna push it) so it should make all it's power below that...or would simply going to 1.6RR be enough? that swap wouldn't be too difficult and wouldn't involve me tearing the front part of the engine down...
I'd prolly go in this order: X-Ram, NOS, Cam or 1.6RR...
i'd just like to hear from some people that have tried some different things and what you got out of it...i know first thing's first...gotta ditch the stock intake...
Old Feb 26, 2004 | 08:27 AM
Alcee1's Avatar
Alcee1
Default Re: CROSSFIRE OWNERS - Got some questions... (Omega1)
I'll stand by the X-ram. 25HP is not unrealistc. Check my sig.....
Old Feb 26, 2004 | 10:21 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Alcee1 Has done it all well. Looking forward to seeing his vette.
Also check out the crossfire forum. http://www.crossfire.webhop.net
tony
:thumbs:
Old Feb 26, 2004 | 11:15 AM
Dominic Sorresso's Avatar
Dominic Sorresso
Omega1,
I think you can get the +25hp from the Xfire manifold. That's also been demonstrated on the Crossfire Vault. Right now, my manifold is supporting about 340hp. That's not saying the Xfire manifold is the greatest manifold ever. Its just not the abomination some people make it out to be. Some people on this forum and on the Xfire forum are running 13's with the stock ECM. I'm not a proponent of that but its obviously possible. The stock heads are not optimum. But again, some have run 13's with them.
Old Feb 26, 2004 | 01:28 PM
CFI-EFI's Avatar
CFI-EFI
With 160,000 miles on it, I've run a best of 13.86 i the 1/4. The long block is untouched, just as GM put it together 20 years ago. Like Dominic, I am using a ported origional Crossfire manifold. Good luck, and...
RACE ON!!!
Old Feb 26, 2004 | 03:57 PM
Omega1's Avatar
Omega1
Alcee1, does that 2030 compucam work well with the stock ECM? i've heard a few people use it with no tuning and get excellent results...also where did you have the chip done? i see you've done quite alot and according to your sig aren't running a 7747 or PROMinator or other computer mods that i've heard of. Of course i gotta ask, what numbers does she put up? it's a very impressive car!
there is no one else around here that can do that level of port work and i don't trust myself doing it. Even if a shop here agreed to do it, they'd prolly screw it up and then charge me as much as it would cost to just buy the X-Ram in the first place...if there was a reputable shop (or person close to me) that would undertake the project for a decent price, i'd have to at least consider it...
[Modified by Omega1, 3:01 PM 2/26/2004]
[Modified by Omega1, 3:04 PM 2/26/2004]
Old Feb 26, 2004 | 05:22 PM
Alcee1's Avatar
Alcee1
Omega1, the 2030 works great with just a custom chip, prolly the stock chip will work also but I wanted mine dialed in just right. I also heard that the 2040, if you want to go more rad will work with the stock ECM also. The chip I had Exotic Muscle burn, they got it right the first time. In case they don't get it right the first time the second burn is free. As far as times are concerned, I won't know that until march when I go to the track, I should be getting my car dyno'd in a couple of weeks then I'll post numbers. Thanks for the compliment, I try and take care of my car the best I can. My advice to you if your not sure about porting you manifold and there is no-one who you trust to do a good job then get the X-Ram (if your money is right) you wont be disapointed. GOOD LUCK... :thumbs:
Old Feb 26, 2004 | 08:17 PM
Omega1's Avatar
Omega1
I'm eager to see what it can do...i'm absolutely blown away by the look of it even from that angle. it's basically what i wanted to do to mine except i wanted the sidepipes...thanks and good luck at the dyno/track!
Old Feb 26, 2004 | 08:37 PM
Dominic Sorresso
Omega1,
Here's mine with the ZR-1 wheels and the C5 brake upgrade in the front. This is before the ZF6 TRANS-plant and the MagnaFlow CATback.
[Modified by Dominic Sorresso, 7:39 PM 2/26/2004]
[Modified by Dominic Sorresso, 7:40 PM 2/26/2004]
Old Feb 26, 2004 | 08:50 PM
Omega1's Avatar
Omega1
me like...
i'll have to toss a pic of mine up when i get home...
it needs interior carpet and seat covers bad, and paint, but otherwise runs and drives fine...
Old Feb 26, 2004 | 08:55 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: CROSSFIRE OWNERS - Got some questions... (Dominic Sorresso)
Looking forward to seeing the after picture.
RACE ON!!!
[Modified by CFI-EFI, 6:59 PM 2/26/2004]
Old Feb 26, 2004 | 11:50 PM
Omega1's Avatar
Omega1
Default Re: CROSSFIRE OWNERS - Got some questions... (CFI-EFI)
foreground is my 1984 crossfire, and the background is my 1977 L48 4spd...
they need alot of work as i said...77's gettin a 427 as soon as i'm not broke...but it also basically needs a restoration. Functionally it runs and drives alright, it's just not in the condition where i'd show it at all...got the engine but don't have the cash to install it...
the 84 is in better shape, needing only carpet, seat covers, and small miscellaneous parts in addition to the digital dash. i paid 4k for it with 132k on it but 7k on new motor/rebuilt trans/rear end...not bad...someday she'll be getting a full greenwood kit with the sidepipes...i love the looks of the greenwood kits..
To CROSSFIRE OWNERS - Got some questions...
