Track Times
Old Feb 26, 2004 | 11:27 AM
BMarsh93's Avatar
BMarsh93
Default Track Times
The first time out with the '95 was a little disappointing. I ran a best of 9.15@79.8mph w/ a 2.16 60'. My dad raced the '87, 8.86@79.4 w/1.98 60'. I realize the '87 ran a better time due to traction, but shouldn't I be at least running about 82mph or faster? Check out my signature, I've got a small list of mods to both cars. I think my '95 should have alot more power what does everyone else think?
Old Feb 26, 2004 | 08:50 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Track Times (BMarsh93)
Sorry I'm away from home and can't convert to 1/4mi times.
Maybe someone will come in with some data.
Old Feb 26, 2004 | 09:00 PM
JackDidley's Avatar
JackDidley
ET for the 87 is about right. I have one. It will be around 13.9 1/4 mile. I Dont have much experience with LT1 cars but I would expect a bit better with that cam. Tire spin can really kill your ET though. Keep racing, practice will help :jester
Old Feb 26, 2004 | 09:21 PM
CFI-EFI's Avatar
CFI-EFI
I think there are some "standard" factors for converting 1/8th time to 1/4 times. Here are some actual numbers that are in your ballpark.
60'...................1.916
1/8th ET.........8.852
1/8th MPH...78.50
1/4 ET..........13.861
1/4 MPH.......98.23
I hope this helps.
RACE ON!!!
[EDIT] Trying to get numbers to line up.
[Modified by CFI-EFI, 7:30 PM 2/26/2004]
Old Feb 26, 2004 | 09:23 PM
JackDidley's Avatar
JackDidley
Default Re: Track Times (Spankyellow)
Looks like one of my time slips :iagree:
Old Feb 26, 2004 | 09:51 PM
BMarsh93's Avatar
BMarsh93
It looks like I'm right on with the '87. Anyone have times or opinions on the '95? The only things I can think of that may have influenced the low mph:
1) Car was real hot 220-230 on every run. Everything about my cooling system is factory except for T/B Bypass.
2) I've heard the LT-1 Knock Sensor is real sensitive. Could the fact that I have a Hot Cam with roller rockers affect this sensor?
Old Feb 26, 2004 | 09:53 PM
95_6spdvette's Avatar
95_6spdvette
I ran 8.98 at 79.51mph in the 1/8, i was also shifting 1,000 rpms short and had a 2.14 60ft, bone stock 95 6spd, yours should be faster!
Old Feb 26, 2004 | 10:27 PM
mickeyt's Avatar
mickeyt
Default Re: Track Times (95_6spdvette)
93 six speed, 355 gear, street tires. could not hook-up, also brook loose in secound gear.
R/T 1.174
60 2.038
330 5.883
1/8 8.89
MPH 80.89
1000 11.616
1/4 13.842
MPH 101.13
Rockingham dragway
NC
:auto:
Old Feb 26, 2004 | 11:17 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: Track Times (mickeyt)
I have a 93 and this is what I ran without the N2O..
60' = 1.932
330'= 5.746
1/8= 8.902@77.75
1000'=11.633
1/4=13.969@95.95
Old Feb 27, 2004 | 01:23 AM
TIMSPEED's Avatar
TIMSPEED
That's nice! On my 87 Z52 With Hooker Super Comp's, Straight Mandrel Bent 2½" Piping, 2600rpm Stall Converter and drag radials ran these numbers:
60' = 1.86
330' = 5.566
1/8th Mile = 8.672 @ 78.8mph
¼ Mile = 13.59 @ 100.9mph
So, I'd say your car is running QUITE well for having LESS mods than mine! :cheers:
Old Feb 27, 2004 | 04:21 AM
gears's Avatar
gears
Default Re: Track Times (TIMSPEED)
Dont be too hard on yourself till you do the 1/4 mile.The time in my signature,I think I ran 86 mph in the 1/8,and usually 84-85.But it pulls like a banshee on the big end.I didnt gain that much mph wise in the 1/8 from stock,but it sure made up the difference on the last half of the 1/4.They like rpm :D
Old Feb 27, 2004 | 06:44 AM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
First, what were your 60' times. The 1.8 ET does seems a slow for your car - a stock LT-1 even. I would think 8.80s would be very real if not quicker. My LT-4 has 1/8 ETs between 8.34 and 8.55 depending on 60'.
Yes, at 220 degrees you are negatively impacting HP. You will find ET with a 160 or 180 Thermostat and programming your fans to come on much sooner.
And Yes to the knock sensor. I have heard many guys buy an LT-4 knock sensor when they go the hot cam route. I just am not sure about the HP impact.
Good luck!
Old Feb 27, 2004 | 11:24 AM
BMarsh93's Avatar
BMarsh93
Default Re: Track Times (LT-4 CE)
Thanks to all for your help. I will be checking into a low temp thermostat and low temp fan mod.
To Track Times
