I'm looking into a window issue and am replacing the weather seals at the same time for the forst time. I am having issues removing the handle bezel and need to know how to get it off of the handle an over the auto door lock mech.
The only area giving any resistance is from the center of the panel around the bezel and I have removed the two screws, one behind the light and one behind the handle. Any help is appreciated. :confused:
Move the locking slide to the OPEN position. Use a small blade, standard screwdriver and place it behind the slide. Pry to you. the plastic cover piece will pop off. You will see the lock rod. Behind the rod is another screw.
