Oil Pump Question on 86 L98
Old Feb 26, 2004 | 06:43 PM
zog's Avatar
zog
Default Oil Pump Question on 86 L98
I am in the process of replacing the timiing chain on my 86 Vette, and decided that at 101,000 miles I'll go ahead and replace the oil pump as long as I have the oil pan off.
I bought a Mellings oil pump, but I read that the sump piece that goes into the oil (with the screen) is welded to the oil pump.
Should I have bought an oil pump with the sump already installed (welded)? I thought the sump part simply press fits into the hole in the side of the oil pump??? Am I goofy or ????
Help... :cheers:
Old Feb 26, 2004 | 06:45 PM
vader86's Avatar
vader86
Default Re: Oil Pump Question on 86 L98 (zog)
It would be better to tack the pickup on the new pump, but its not required.
Old Feb 26, 2004 | 08:18 PM
Pete K's Avatar
Pete K
Default Re: Oil Pump Question on 86 L98 (vader86)
If you don't have access to a welder or are afraid of damage to pump from welding heat, Jegs has a punp safety retainer. It costs about$8 and bolts to pump and pickup together.
Old Feb 27, 2004 | 12:34 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Oil Pump Question on 86 L98 (Pete K)
i'm sure you can take it to a weld shop and have it done cheap... but $8 isn't a bad deal either... :yesnod:
Old Feb 27, 2004 | 01:30 PM
JAKE's Avatar
JAKE
Help... :cheers:
The part you're referring to is the pickup.
If you decide to have it welded or tack welded, just make sure the guy removed the pressure spring from the pump first so that the heat doesn;t effect the spring tension. It's simple to remove and re-install.
Tacking the pickup is recommended but not absolutely mandatory.
Jake
Old Feb 27, 2004 | 03:36 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Oil Pump Question on 86 L98 (JAKE)
Jake
:iagree: But for peace of mind, I always tack the pickup to the pump body. You don't have to have a bead completely around the pickup tube, just enough to insure the pickup doesn't vibrate out of the pump body.
Also, when welding, remove the spring as mentioned above.
Old Mar 1, 2004 | 12:56 PM
zog's Avatar
zog
Default Re: Oil Pump Question on 86 L98 (JCAIRE2)
Thanks for the replies...I was under the impression that the pickup was already supposed to be welded to the pump. I guess I will get it tack welded...just feel safer. Thanks :cheers:
To Oil Pump Question on 86 L98
