85' Gauges
Old Feb 26, 2004 | 09:30 PM
Redrum11's Avatar
Redrum11
Default 85' Gauges
Hey, the illumination behind two of the three digital gauges have gone out. The only one still lit is the tach. This has happened before but they all lit up again when I tapped the plastic sheild. I tried this again but it didn't work. Any suggestions as to what the problem could be and how to solve it? Thanks.
Old Feb 26, 2004 | 09:31 PM
timmytcc's Avatar
timmytcc
Default Re: 85' Gauges (Redrum11)
ever try to replace the bulbs???????????
Old Feb 26, 2004 | 10:12 PM
VtVette's Avatar
VtVette
Default Re: 85' Gauges (timmytcc)
Usually, if you can tap it and it comes back on it's a bad ground. Don't keep tapping it, as it can cause further damage.
If you're a DIY'er, you can take it apart and usually find the culprit if you look hard enough. The power and ground circuits on the cluster's printed circuit board are pretty easy to locate, just trace them and look for any loose/broken contacts.
If you find a problem, and you're not a solderer, you can bring it into a electronics repair facility and they can fix it for you.
there was a great article about fixing your own dash I used to see on the forum. Do a search or post a message asking someone to post the URL.
It tells you how to diagnose most problems with the digital dash, and how to fix them.
Good luck,
VtVette
Old Feb 26, 2004 | 11:04 PM
h rocks's Avatar
h rocks
A good friend of mine has an 85 that he took off the road at 15,000 miles. He has LOTS of stuff that's like new that he will never use again. If you're interested in a dash, A/C unit and related parts, full intake incl. fuel rails and injectors, ported MAF, rare SLP stainless LT headers and Y pipe etc. etc. let me know and I'll get you in touch with him.
Old Feb 27, 2004 | 12:27 AM
Southern Comfort's Avatar
Southern Comfort
Default Re: 85' Gauges (h rocks)
'took it off the road at 15k and parting it out? What did he put a whole new engine in?
Old Feb 27, 2004 | 01:42 AM
Omega1's Avatar
Omega1
Default Re: 85' Gauges (Southern Comfort)
if that dash will work in my 84 i'm game as soon as my flippin tax check gets here if he still has it by then...mine went out and i can't stand it any longer...
Old Feb 27, 2004 | 03:41 AM
ffvetteman's Avatar
ffvetteman
The cluster can be rebuilt and bulbs replaced which will solve the problem.
I did mine last summer and it worked great.
I did it myself.
Old Feb 27, 2004 | 12:13 PM
rick lambert's Avatar
rick lambert
Default Re: 85' Gauges (ffvetteman)
Everyones problem, try http:/www.corvettedashclusterservice.com/Ucando%20Process1.html :D you might only need to enter corvettdashclusterservice.com
I'm doing mine when weather permitts. seems to cure the problem according to most guys. :seeya
To 85' Gauges
