connecting scanner cable
Old Feb 26, 2004 | 09:58 PM
toplsvette's Avatar
toplsvette
Default connecting scanner cable
Hello All,
I have a silly question... I am trying to use the DataMaster software and cant seem to link up with ECM.. I get a error that says adapter OK no PCM connection...Well, I have tried every combination on the obd1 port and nothing... Can someone please tell me what pins are used? ie.... pins A,B & E....
TIA
Eddie
Old Feb 27, 2004 | 07:34 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: connecting scanner cable (toplsvette)
You'll need a 10Kohm resistor between pins A&B. Red wire goes to A, black to B. Data comes from pin E.
Old Feb 27, 2004 | 09:02 PM
toplsvette's Avatar
toplsvette
Default Re: connecting scanner cable (JCAIRE2)
Cool,
Thats what i was lookin for...
Thanx,
Eddie
Old Feb 28, 2004 | 02:46 PM
corvette90's Avatar
corvette90
pin "E" ??
i always thougth pin "m"
:confused:
Old Feb 28, 2004 | 03:50 PM
toplsvette's Avatar
toplsvette
Default Re: connecting scanner cable (corvette90)
I believe a 90 is pin "M" because it is MAP
My 88 doesnt have a pin "M" because it's MAF
Old Feb 28, 2004 | 04:07 PM
JCAIRE2's Avatar
JCAIRE2
did it work?
Old Feb 29, 2004 | 12:21 PM
toplsvette's Avatar
toplsvette
Gonna try again today... Will let you know...
I checked the cable I have and there is a 10k resistor between A & B, so hopefully it will work.. I think I had the A and B switched around the first time..
Old Feb 29, 2004 | 09:52 PM
toplsvette's Avatar
toplsvette
well, turns out all the problem trying to scan the computer is because the custom chip I had burnt wont scan... I am having another chip made and will try again this weekend...
To connecting scanner cable
