I need to address this
Old Feb 26, 2004 | 10:55 PM
1990CORVETTE's Avatar
1990CORVETTE
Default I need to address this
One more time.....
My car has the performance rear-end 3.07's and for reason at highway speeds it cruises at high RPM's.
For example at 80 I am at 3000rpm's,,,,
Can anyone shed light on this for me.....
I know they are 3.07's, because I have jacked the car up and spun the wheels and watched the driveshaft spin 3 1/8 times.....
Any one???????????? :banghead: :banghead: :banghead:
At 80 MPH
At 70 MPH
[Modified by 1990CORVETTE, 9:56 PM 2/26/2004]
Old Feb 26, 2004 | 11:00 PM
Pete K's Avatar
Pete K
Default Re: I need to address this (1990CORVETTE)
If car is an auto, torque convertor may not be locking up. this will raise cruise rpm approx 200 rpm
Old Feb 26, 2004 | 11:07 PM
SPEED750's Avatar
SPEED750
Default Re: I need to address this (Pete K)
You've got some issues there.Are you even getting into overdrive?That is way wrong. :eek:
Old Feb 26, 2004 | 11:08 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: I need to address this (SPEED750)
:withstupid:
There is something BIG wrong with the tranny or TC
Old Feb 26, 2004 | 11:16 PM
1990CORVETTE
Default Re: I need to address this (fsr402)
The tranny is brand new with a new 2600 stall... It has about 2000 miles on it...
It was professionally rebuilt...... Could it be the tach itself, it doesnt jump or anything. It shifts through all the gears perfectly, with no problem at all... How do i check if the TC is locking up? When I step on it at 70 MPH, there is no jump in the tach,, it just rises with the speed of the car :smash: :smash:
The reason i want to ask these questions now ,,, is the tranny is under warranty and I want to address all problems
TIMSPEED's Avatar
TIMSPEED
Are you sure it's shifting into Overdrive?
Old Feb 26, 2004 | 11:23 PM
1990CORVETTE
Default Re: I need to address this (TIMSPEED)
I am shifting into all 4 gears :yesnod: :yesnod: :yesnod:
Old Feb 26, 2004 | 11:29 PM
Pete K's Avatar
Pete K
To check lock-up cruise down the highway at a steady speed above 45 mph. while foot rests on gas pedal squeese brake with left foot. you should hear convertor unlock and rpm climb 2-3 hundred rpm. when foot lifts off brake pedal you will hear rpm change as convertor locks back up. Remember constant smooth power applied with throttle
Old Feb 27, 2004 | 12:09 AM
JCAIRE2's Avatar
JCAIRE2
:iagree:
Old Feb 27, 2004 | 12:13 AM
vetterlatethannever's Avatar
vetterlatethannever
What are your MPG at these speeds? If they are still high then it could be just the tach. Those RPMs are way too high IMHO.
Old Feb 27, 2004 | 12:18 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
good info :thumbs:
Old Feb 27, 2004 | 01:02 AM
nodoubt's Avatar
nodoubt
Are your rims bent?
My sister hit a curb and bent the rims on the rear of her 1990 Vette, making her speedometer report 55 mph when she was actually doing 70 mph.
That would certainly explain higher rpm's...if you were actually going faster than than your indicated 70 mph at 3000 rpm.
[Modified by nodoubt, 12:05 AM 2/27/2004]
Old Feb 27, 2004 | 01:13 AM
1990CORVETTE
Default Re: I need to address this (nodoubt)
NO bent rims here
Old Feb 27, 2004 | 01:24 AM
metropolis's Avatar
metropolis
Are you in D or OD?
Old Feb 27, 2004 | 01:50 AM
1990CORVETTE
Default Re: I need to address this (metropolis)
OD :jester :seeya
Old Feb 27, 2004 | 01:52 AM
scorp508's Avatar
scorp508
Congratulations you own a 1990 Corvette. Also known as the C4 with THE most innacurrate tachometer of all the years! I watched my buddy on the dyno let off at 5000 RPM when his tach said 6000 RPM. This was a stick car, no torque convertor to slip. Slap a scan tool on there and see if it really is at 3000 or not.
Old Feb 27, 2004 | 02:01 AM
StealDads67's Avatar
StealDads67
Does it sound like its at 3000 rpms???
Dont really understand the whole bent rims theory.... but ok
To I need to address this
Old Feb 27, 2004 | 02:02 AM
1990CORVETTE
Default Re: I need to address this (scorp508)
Scorp,
Where do I get a scan tool?What kind? where do I plug it in at? The place right below the steering wheel right??????
I thought something was wrong for a while,,, when I got it back from the shop the tach jumped a little bit here and there ,,, but it stopped.......
Why would the TC slip? Is it an adjustment thing or what,,,, would I feel it slip..... :confused:
Old Feb 27, 2004 | 02:05 AM
1990CORVETTE
weird thing is ,,, is one day I had it up to 128 and it only registered about 4200 rpms,,, is that normal :cool:
Hope I dont get in trouble for saying that :nono:
Old Feb 27, 2004 | 02:09 AM
scorp508's Avatar
scorp508
You need one of the ones that are capable of monitoring te ALDL port's datastream. You've probably seen us mention a lot of different ones.
Diacom+
Datamaster
EASE
Snap-On MT2500 (and other models)
Autotap
GM Tech 1/2
They're all kinda pricey and some require a laptop to run on also. If you've got somebody in the area with one they should be able to do this in a heartbeat for you. Maybe you can even sweet talk a local mechanic to spend 5 minutes with you to see if its ok or not.
Can't really adjust it unless it was a fluid issue. Worst case scenario would be that some of the fins inside the TC are not angled correctly (or fragged) and causing excessive slippage.
