what is the recomended part # that i'd use for my L98 non-stroker. is it just a simple internal balanced sb chevy? thanx for any help guys and gals :thumbs:
L-98 with 1 pc rear main seal crankshaft have an external balance balancer. Be aware though it is a different external than earlier chevys. It is specific to one piece seal type crank. An 85 L98 has 2 pc crank.It uses the internal style.So much for chevy being interchangeble.
Actually, the 1 piece seal cranks are internal balance on the front half of the crank, and external balance on the rear half of the crank. So you can use a "normal" internal balance dampner.
[Modified by tpi 421 vette, 10:48 AM 2/27/2004]
Right. The add'l weight is on the flex-plate/flywheel and the damper is neutral balance.
Sorry guys , my balancer (87 oem) had a notch missing so I thought it was external.I was wrong but my wife says I am wrong alot. Wont let her see this post. Sorry for the confusion. :sad:
thanx guys,im a little confused but i might just build a 383 with a ex bal.400 crank to make it esier. and its a 2 piece rear so i guess it makes it real easy now.
so if i used a 1 piece rear block from a 89 vette and stock internals i'd have to .....use an internal dampner? :confused:
Okay, here's the deal.
The stock TPI engine is a hybrid. It has a neutral balance damper (no additional weight added) and a flex-plate WITH additional weight.
If you go with a 400 crank, then the engine becomes externally balanced - meaning weights will be called for on BOTH the damper and the flex-plate UNLESS
You specific to have the crank internally balanced (calling for mallory metal) inwhich case you'd use a neutrally balanced damper and flex-plate/flywheel.
Now when going with a 400 crank and maintaining the EXTERNAL BALANCING, the size of the damper becomes a concern. A 400 calls for a larger diameter damper that the 350 does and this creates a clearance problem at the lower front of the engine.
You'd need an EXTERNAL DAMPER with an OD of 6-3/4" to clear without having to modify the car for the needed clearance.
thanks JAKE,solved a little confusion in my head last night
i wanted to replace my new motors stock one with a superior one. either an ATI or a Fluid.still debating on 406 or 383.i have a 400 blk already also.so im still plannin.i want more speed so prolly the bigger brother will get chosen.
:cool:
Yep, and I'm running stock Chevy 5.7" rods on a 400 crank with TRW pistons that have standard ring spacing (oil ring set NOT in the pin hole). So I guess a little ingenuity goes a long way.
