Battery Question
Old Feb 27, 2004 | 08:39 AM
lpguthrie's Avatar
lpguthrie
Default Battery Question
What if any problems has anyone had with a battery that appears to be fine (starts o.k.) but may be low...Any problems with dash lights, cruise,anything of that nature??? Just a thought... :confused:
Old Feb 27, 2004 | 09:37 AM
jfb's Avatar
jfb
Default Re: Battery Question (lpguthrie)
If the engine is running the alternator supplies the electrical power and the state of the battery doesn't matter. At idle though and with a heavy electrical load it is possible to exceed the alternators reduced current capacity and the battery will assume the difference current and the voltage will sag. 12.0 volts and lower for a lead acid battery is considered a discharged battery.
