Fuel Pump Question
Old Feb 27, 2004 | 05:36 PM
8835thL98's Avatar
8835thL98
Default Fuel Pump Question
What are symptoms of a bad fuel pump? Is there anyway to do a test before replacing one? Would any of the symptoms apply to this post??
http://forums.corvetteforum.com/zerothread?id=764055
Old Feb 27, 2004 | 05:41 PM
scorp508's Avatar
scorp508
Default Re: Fuel Pump Question (-=Persephone=-)
If you don't have one then buy yourself a fuel pressure gauge for $25 or so bucks at autozone that is on a 2' hose. WIthout it you're shooting darts with a blindfold.
Old Feb 27, 2004 | 06:17 PM
Wheelman's Avatar
Wheelman
If you are getting proper voltage at the pump contacts, and can hear the pump coming on, then check pressure at the rail. If you are getting proper pressure at the rail, (around 38-42psi i believe) then your problem is else where. If you arent gettting full pressure, you need to check your fuel lines for restrictions. If you find none then my guess would be the pump is defective
Old Feb 27, 2004 | 08:46 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Fuel Pump Question (Wheelman)
:iagree:
Old Feb 27, 2004 | 08:47 PM
CFI-EFI's Avatar
CFI-EFI
See your other post on this same subject.
RACE ON!!!
To Fuel Pump Question
