Check your clips
Old Feb 29, 2004 | 03:37 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Check your clips
the little clips that hold the brake caliper pins on the front. I had one break in half and the other wasn't even there.
So now my car sits with new brakes, but no clips to hold the pins, gotta wait till tomorrow to get new ones.
Old Feb 29, 2004 | 05:15 PM
abtanner's Avatar
abtanner
Default Re: Check your clips (Mr Mojo)
I got replacements (two ea.per package) at Home Depot , 5/16 ", $.33.
Old Feb 29, 2004 | 05:16 PM
bogus's Avatar
bogus
ick.
Thanks for the tip on home depot! :cheers:
Old Mar 1, 2004 | 08:12 AM
LoneStarSoldier's Avatar
LoneStarSoldier
Default Re: Check your clips (bogus)
Thanks for the tip, this can cause big problems. Had a good friend killed because of a clip when Disc brakes first come out.
HAVE A GREAT DAY!!! :flag
Old Mar 1, 2004 | 01:01 PM
jmrl98's Avatar
jmrl98
Dumb question time - do all C4s have these, or just certain years? :steering:
Old Mar 1, 2004 | 03:02 PM
JasonL's Avatar
JasonL
Default Re: Check your clips (jmrl98)
This post applies to all 88-96 front brakes.
I will occasionally reuse the pins and clips, but at the first sign of wear or bending, it goes in the trash. They look like regular old e-clips to me, which are available at OSH/Home Depot. Hopefully those are just as strong...
Old Mar 1, 2004 | 03:51 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Check your clips (JasonL)
My '88 GM Shop Manual instructs to install new pins & clips when doing pads so I did.
Old Mar 1, 2004 | 04:33 PM
ZylaRace's Avatar
ZylaRace
Default Re: Check your clips (65Z01)
Carefull w/ the Depot E clips. They are markedly thinner than the GM version. Not worth me risking a wheel lockup.
Old Mar 1, 2004 | 05:37 PM
96LT1's Avatar
96LT1
:iagree: For the couple of bucks it costs to replace the pins and clips I can't see not doing it.
Old Mar 1, 2004 | 05:44 PM
rick lambert's Avatar
rick lambert
Default Re: Check your clips (96LT1)
I think I would be aweful careful using the Home depot clips, there just might be a considerable difference in hardness factor as well.Home versus auto? I don't think so. :skep: You might be lucky for awhile, but is it really worth a few bucks difference? :skep: :skep: :skep:
Old Mar 1, 2004 | 05:53 PM
JasonL's Avatar
JasonL
Default Re: Check your clips (rick lambert)
That's what I was wondering... perhaps the GM clips are made to a higher standard than run-of-the-mill home repair parts.
I noticed one Camaro-Mustang-Challenge racer (3rd gen F-body) had switched to clevis pins and spring clips. I might do that sometime.
By reusing the pins/clips, I'm referring to parts that are only a few months old and still look new. If in doubt just replace them.
To Check your clips
