I just ordered the 25# Bosch injectors from SLP because I read that they were a good replacement but, after searching on this subject on this sight as well as thirdgen.org, I found that the engine will run rich unless an AFPR is installed or a new prom is burned.
I just want a stock replacement type injector that will fit and perform without any modifications.
Can anyone recommend a good place to buy the stock 22# injectors? Or can anyone recommend another type injector set that will work on a stock 89 L98 engine without any other modifications to the engine?
I live in California and want to keep the engine mostly stock for emission reasons. Thanks for your help
If interested, I have a complete set that I have less than 3000 miles on.
They were purchased from http://www.tpis.com (300-510)and they are a matched set.
$175 takes them all.
I paid over $400 for them.
I upgraded my 383 per my sig and went with Ford #24.
