Brake upgrade
Old Mar 1, 2004 | 09:40 AM
Dudule's Avatar
Dudule
Default Brake upgrade
Hi guys
I'd like to change my 92 brakes into something that can be really called "brakes"...I am tired off this impression of having a useless left pedal... :(
Can somebody give me some advice of what kind of upgrade I should install on my car and where to get it...I just want more efficient brakes so that I can have some fun with less risk of ending in a tree with hot brakes but I am not looking for a racing stuff as I don't drive with full throttle often (not for the time :D )
Old Mar 1, 2004 | 10:17 AM
QuikZilver's Avatar
QuikZilver
Default Re: Brake upgrade (Dudule)
There are a couple of options depending on the brake system you have.
1. Install DRM Brake Bias Spring in Master Cylinder. (Cheapest upgrade)
2. Install S/S Brake hoses. (Holds more pressure)
3. Flush brake system and replace fluid with Ford HP brake fluid (higher boiling temps)
4. Upgrade front brakes from standard 12" to J55 C4 13" Big brakes. (Kits cost around $800-900)
5. Upgrade front brakes from standard 12" to C5 13" Brakes. (Put your own kit together for $300-$800 depending on options. Contact forum member, edalinas for caliper adaptors, his are great and inexpensive. See http://www.superchevyperformance.com under their brake upgrade section for a list of parts needed. You can find used calipers in the C5 Parts section of the forum or buy new ones. Z06 and reg. C5 calipers are the same, only difference is the color.)
6. Go to Wilwood or higher performance brake system. Be prepared to pay a lot more.
:cheers:
Old Mar 1, 2004 | 07:25 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Brake upgrade (Whitvette)
:cheers: The stock C5 front brakes and the DRM bias spring are an awesome and relatively inexpensive combination.
I have read the test reports, Vette Fever or Vette, can't remember which one, on the Willwood upgrade and for several thousand bucks more, the results amounted to a few feet of stopping distance!
Go for the C5 and the DRM spring and talk to Ed about adapters. I bought my C5 front brakes cheap on C5 parts for sale from some guy who had to move up to Willwood :rolleyes:
:seeya
:steering:
Old Mar 1, 2004 | 07:34 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: Brake upgrade (jackdaroofer)
Jack, the difference between the C5 calipers and the baer/Brembo/Willwood kit's is not the extra 2 feet or whatever you justify your money on, it's the ability to reduce fade after repeated high speed stops from road racing or certain autocross events.
You might want to ponder upon what the person doing the upgrade wants to do, rather than automatically bad mouthing what could be a proper upgrade.
Old Mar 1, 2004 | 11:51 PM
vette92_1's Avatar
vette92_1
:cheers:
:iagree:
What he said. :yesnod:
Old Mar 2, 2004 | 02:21 AM
JasonL's Avatar
JasonL
:eek: You can source the parts yourself for less than half of that. I sold a pair of J55 calipers for about $75.
Old Mar 2, 2004 | 05:19 AM
Dudule's Avatar
Dudule
Thanks for your help, I atually want something that increases the braking efficiency of the vette but not for a racing purpose...
Old Mar 2, 2004 | 07:31 AM
DON M's Avatar
DON M
Then the C-5 parts are the answer for you. :thumbs:
I couldn't be happier with my set up. (see sig)
Old Mar 2, 2004 | 09:53 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: Brake upgrade (DON M)
REMEMBER you cannot use stock sawblades with the C5 brake upgrade! :yesnod:
Old Mar 2, 2004 | 09:58 AM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Brake upgrade (VictorRussell'92)
If you add a 1/2 inch spacer they will work!!!!
EDIT: If your talking about the 16" saladshooters, your right??
[Modified by edsalinas, 8:05 AM 3/2/2004]
Old Mar 2, 2004 | 10:23 AM
VR'92's Avatar
VR'92
St. Jude Donor '03
Default Re: Brake upgrade (edsalinas)
I always heard they wouldn't work with 17in sawblades on my 92. I have definitly had poeple tell me that. Am I wrong? That would be great! :)
Old Mar 2, 2004 | 10:31 AM
edsalinas's Avatar
edsalinas
I assembled them on my '92 stock sawblades, without a wheel adapter the C5 caliper hits the rim where the 8 ribs curve into the outer portion of the wheel. But with the use of a 1/2 wheel spacer (from Mid America/Ecklers etc), they fit just fine.
:cool:
Old Mar 2, 2004 | 12:49 PM
Dudule's Avatar
Dudule
Cool, so I think I'll put C5 calipers on my 92...
What about the pads?
And can somebody list me all the parts I need for the compete upgrade so I know what to order (and where)...
Thank you very much guys
:thumbs:
Old Mar 2, 2004 | 01:13 PM
QuikZilver's Avatar
QuikZilver
http://www.superchevyperformance.com: This is Superior Chevrolet's website. They put together a full list of the parts that are needed. Their prices for the parts are excellent as well! If you want to go used, check the C5 Parts section. A lot of guys have gotten calipers for the front really cheap from other guys on the forum. Get with edsalinas for the adaptors. I went with the ceramic GM pads and the high performance GM rotors for my setup.
:cheers:
To Brake upgrade
