Cheapest way to scan using windows?
Old Mar 1, 2004 | 10:51 AM
LD85's Avatar
LD85
Default Cheapest way to scan using windows?
Is EASE the cheapest way to scan my 165 ?
Old Mar 1, 2004 | 02:23 PM
GRX's Avatar
GRX
Default Re: Cheapest way to scan using windows? (ld85)
I would think WinALDL is the cheapest... :lurk:
Old Mar 1, 2004 | 02:43 PM
Bluevette85's Avatar
Bluevette85
Moates (free), Datamaster
(edited by Marcho Polo because of unwanted content) :D
[Modified by Marcho Polo, 10:54 PM 3/1/2004]
Old Mar 1, 2004 | 03:46 PM
kaiser's Avatar
kaiser
Default Re: Cheapest way to scan using windows? (Bluevette85)
Uh, Bluevette85, just an FYI. There was a fellow who got bounced off the Forum not too long ago for advocating sortware piracy. The forum sponsors generally take a dim view of people stealing things and then bragging about it. You might want to edit the post above. If you do, I'll delete this one before any of the mods notice. Up to you.
Old Mar 1, 2004 | 03:55 PM
Bluevette85
Default Re: Cheapest way to scan using windows? (kaiser)
Thanks for your concern :rolleyes:
I'm not advocating anyone pirate software. Just pointing out that there is a way to extend the trial period of software that can be downloaded for free so you can decide if you want to license it.
Old Mar 1, 2004 | 04:03 PM
LD85's Avatar
LD85
Cool, I want a program that will work in Windows,
but do anyone of them work in Windows XP?
Old Mar 1, 2004 | 04:11 PM
DVNCI's Avatar
DVNCI
No kidding . . . I WILL buy the software and indeed want to but I can't get them to help me figure out my problem!!!!!!!!!!!!! :mad
Old Mar 1, 2004 | 06:27 PM
JCAIRE2's Avatar
JCAIRE2
I've had success with datamaster so far, but not the moates software nor winaldl.
Old Mar 1, 2004 | 06:28 PM
LD85's Avatar
LD85
Default Re: Cheapest way to scan using windows? (JCAIRE2)
Thanks, I will pick up the Datamaster & their cable
Old Mar 1, 2004 | 07:31 PM
Bluevette85
You might want to check out the Autoprom. You can program in real time then burn a final chip. The software, Tunerpro, does the programming and aldl monitoring all in one. Here are the links:
www.moates.net
tunerpro.markmansur.com
This is what I'm using and soon they will have an adapter to log a wideband (or any 3, 0-5 volt inputs sensors)
Old Mar 1, 2004 | 08:18 PM
LD85's Avatar
LD85
Does anyonme make/sell a Diacom cable?
Old Mar 2, 2004 | 12:03 AM
JCAIRE2's Avatar
JCAIRE2
The setup mentioned by bluevette, might be a more practical expense for you Larry. I know you will need quite a bit of tuning to go with that 406, and the autoprom lets you program in real-time as well as run diagnostics. I'm seriously considering it myself, rather than spend the ~200 for a programmer and eraser, I could just install the autoprom and be done with it. Just something to consider.
In regards to the diacom cable. I'm not positive on this, but I believe it is just a MAX-232 based cable, so if you can get the software without the cable, you'd just need a MAX-232 cable to go with it, or you could purchase the package.
If you were actually talking about datamaster, check out Steve Ruse's website http://www.wotelectronics.com/cables.html He sells the MAX-232 cables for a reasonable price, and he's great to deal with. I had bought one of his cables from another forum member and was having problems getting it to connect to my ECM. Even though I didn't purchase from him directly, he still took the time out to email me and discuss the problems I was having. Tell him I sent you to the site. :cheers:
I'll tell you one thing. Running the diagnostics on these cars is quite involved. There is a very steep learning curve associated with it, but it's kinda fun too. Figuring out all the information and what it means will take some devotion.
Old Mar 2, 2004 | 06:17 AM
LD85's Avatar
LD85
Many thanks John, Ol RJ had been tuning my car and I just couldnt burden him for another full summer like last year. We spent weekend after weekend trying to zero in on the tuning beore I finall gave up and pulled the engine.
I will check with some of these web sites today.
Old Mar 2, 2004 | 06:49 PM
h rocks's Avatar
h rocks
From everything I've heard over the years, the Miniram is a real pickle to tune. A speed density Superram is challenging enough.
Old Mar 2, 2004 | 10:25 PM
LD85's Avatar
LD85
Default Re: Cheapest way to scan using windows? (h rocks)
I agree, but I have used up all of my bad luck, so it should get easier from here on out :lolg:
Old Mar 9, 2004 | 11:11 PM
korvette4u's Avatar
korvette4u
just to clear this up a bit.. it was vettek50.. whom got punted. i believe he should not have.. Don't think he was implying stealing any software nor bragging about it.. any ways do u think the general minds if the ecm's are decoded? i think, it is a beaurcacy when doing either.what do you think?
To Cheapest way to scan using windows?
