Front Wheel Bearings
Old Mar 2, 2004 | 01:23 PM
zog's Avatar
zog
Default Front Wheel Bearings
I have an 86 and one front wheel bearing has some play in it... are the front hubs adjustable?? I replaced the rear at $150 each....am I in for another $300??? Thanks
Old Mar 2, 2004 | 01:27 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Front Wheel Bearings (zog)
No adjustment. Pretty much like the rears. Good luck, and...
RACE ON!!!
Old Mar 2, 2004 | 02:10 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Not sure about the '86, but I know on my '94 I replaced it with a unit from a '94 Firebird for over half the cost they wanted for the Corvette one. The only swap I had to do was to swap some mounting bolts. I think it is different for the '86 but may be worth checking out alternatives.
Old Mar 2, 2004 | 03:04 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Front Wheel Bearings (Vette92)
That's a good point, the f-body cars use the same part. I believe all the fronts are the same?? Check with Chris May or Randy Rippie.
Old Mar 2, 2004 | 04:25 PM
JayH's Avatar
JayH
Can you elaborate on that statement? I'm looking at replacing the fronts on my '95 and that would be a good thing to know before I dug into it.
Thanks,
Jay
Old Mar 2, 2004 | 04:57 PM
h rocks's Avatar
h rocks
Default Re: Front Wheel Bearings (JayH)
Check the flange thickness on some of the non Corvette and other than OE units. Many of the C4 replacements are the same bearings/hubs in different boxes, but there are some other suppliers that make the actual bearings/hubs that use a thinner flange. I know two guys that broke them.
Old Mar 2, 2004 | 07:12 PM
JasonL's Avatar
JasonL
Default Re: Front Wheel Bearings (h rocks)
The F-body hub has threaded holes in the flange whereas the C4 hub is unthreaded, using nuts and bolts instead. FWIW in the pics I have, the F-body hub flange is thicker, but that may have to do w/ different brands as well.
Old Mar 2, 2004 | 09:07 PM
OrthoAggie's Avatar
OrthoAggie
Default Re: Front Wheel Bearings (JasonL)
yes this i noticed too that the flange was about 1/4" thicker on the Fbody ones than the Vette one when i switched mine out
To Front Wheel Bearings
