where to set o2 bung
Old Mar 2, 2004 | 05:04 PM
corvette90's Avatar
corvette90
Default where to set o2 bung
hi
just got my WBo2 in from techedge, and now, where should i weld in the o2 bung??
i will use it just for tune purposes...
thank you
Old Mar 4, 2004 | 03:21 PM
corvette90's Avatar
corvette90
Default Re: where to set o2 bung (corvette90)
nobody??
hard to believe ;)
Old Mar 5, 2004 | 03:42 PM
GRX's Avatar
GRX
On my 85 I welded one bung about 3 inches downstream of the stock O2 AND on the same location mirrored over on the other leg of the Y pipe. Make sure the WB O2 sensor ends up vertical up, or at an angle up. Never horizontal. You want moister/condensation to "run off" the sensor to avoid thermal shock when starting up.
To where to set o2 bung
