95 C4 Start Problems
Old Mar 2, 2004 | 07:13 PM
adamk28's Avatar
adamk28
Default 95 C4 Start Problems
My friend has a 1995 C4 automatic with 80k miles. It has developed a start problem after the car is warmed up or has been driven a while. The car will start after waiting 5 to 30 minutes and it starts right up. I have heard of this problem with other C4's but have not heard of the fix. Has anyone had experience with this problem?
Thanks :eek: :confused: :flag
Old Mar 3, 2004 | 02:55 AM
madmike's Avatar
madmike
Default Re: 95 C4 Start Problems (adamk28)
I believe the vehicle has a antitheft device called VATS Vehicle Anti Theft System. On your ignition key its a little chip that is on the key and it connects two wires in the ignition cylinder. It has an ohms rating so the wires cannot be jumped. Try another key if you have one. Mid America Corvette makes a bypass for the system. I have never used it but i hear it just plugs in. VATS usually takes 4 minutes to reset. It thinks someone is trying to steal the car. Hope this helps :seeya
Old Mar 3, 2004 | 08:34 PM
adamk28's Avatar
adamk28
Default Re: 95 C4 Start Problems (madmike)
Thanks Mike,
That part has already been adressed and changed. Didn't GM have a bit of trouble with the HEI distributors during the C4 production until the early 90's?. I am thinking the pickup on the distributor or the distributor itself maybe the culprit. FYI: The coil, MASS Air sensor and a full tune up has been done and a new factory security system has been replaced
Old Mar 3, 2004 | 09:04 PM
Third Gear's Avatar
Third Gear
Your friend has an LT1 which does not have a conventional SBC distributor... I've never heard of a failing Opti Spark doing that. I know it can cause missing under load, and higher RPMs.
That almost sounds like hot starter syndrome you get with headers, like with my friend's 68 Camaro when I did LTs on his car. But I think he has other issues... I doubt LT1s suffer from this.
Old Mar 3, 2004 | 09:11 PM
bogus's Avatar
bogus
I am assuming it's cranking, but not firing?
if that's the case, check into fuel. either the fuel pump or the fuel pump relay.
it could be the coil, too.
Old Mar 3, 2004 | 09:36 PM
Lone Ranger's Avatar
Lone Ranger
Has your friend pulled the Diagnostic Trouble Codes to see if the car has stored a code?
Old Mar 3, 2004 | 09:44 PM
adamk28's Avatar
adamk28
Default Re: 95 C4 Start Problems (Lone Ranger)
Sorry for the typo.. the car is a 1985/86 not a 1995.
Old Mar 3, 2004 | 09:46 PM
adamk28's Avatar
adamk28
the computer is not displaying any trouble codes.
Old Mar 3, 2004 | 09:56 PM
madmike's Avatar
madmike
I would start with the basics. When this happens, check for fuel at the rails, then check for spark. No trouble codes? It really sounds like the VATS. Let us know what you find. :banghead:
Old Mar 3, 2004 | 10:00 PM
jfb's Avatar
jfb
"doesn't start" is not much to go on for us to help you. Does the starter crank the engine and it won't start or does the starter fail to crank the engine?
Old Mar 3, 2004 | 10:19 PM
adamk28's Avatar
adamk28
Default Re: 95 C4 Start Problems (jfb)
The starter cranks and fuel is present.
Old Mar 3, 2004 | 10:25 PM
bogus's Avatar
bogus
I don't know if VATS is a heat sensative problem...
I would check the coil and ignition.
make sure the key has a good chip and it's reasonably clean.
Old Mar 3, 2004 | 10:26 PM
jfb's Avatar
jfb
Automobile engines require spark (and at the right time), fuel, and air to start and run. Check for spark and timing with a timing light. Check for fuel pressure at the shraeder valve on the fuel rail. Connect a low power 12v lamp on the injector plugs and crank the engine and see if the injectors are being pulsed. Remove the flexible air horn on the MAF (mass air flow sensor) to insure that air is getting to the engine. Be sure you do these tests when the engine won't start and let us know what you find.
[Modified by jfb, 9:29 PM 3/3/2004]
To 95 C4 Start Problems
