Canton 240T Oil Pan
i'm pretty sure they didn't send me an f-body pan by mistake, since it looks exactly like the vette 240T in pics i've seen.
also, the rod bolts on my 396 actually hit the side of the pan right below the rail. what a pain having to hammer it out for clearance. i asked canton about this before ordering, since it says on their website that they can accomodate strokers, but they said that the dimension in question can't be fixed. i know others here have used this pan with 396s, did you just hammer?
thanks.
-michael
You may have to trim the pan some with that 396 because the crank sweep is larger. You also should have had to clearence the block area where the oil pan mounts. You may have to clearence the pan inthe same manner.
-michael
i'm thinking a die grinder will fix it.
yes, i'm nervous about how much work it will take to make this pan fit. i'm starting on it this week...
-michael
Mike
i just finished swapping the main studs, ran out of time to do more...
-michael
BTW, I reused the factory oil pan stiffening rail strips w/o problem.
i had to hammer the stock pan a lot to clear the sides also. but, i didn't have to touch the bottom of the pan. i had put together some strokers at mti years ago and those cleared the sides, but hit the bottom. (different rods on those.)
i vaguely remember my builder saying eagle had repositioned the rod bolts recently. maybe i have new style vs yours being old style?
wait, i just caught the motown block part. same pan, though, right? how is that block different? maybe it has a pan rail slightly lower than stock?
-michael
Mike
the driver's side knock sensor was really close to clearing as is. the real problem turned out to be fitting the pan on around the pickup tube. it required me to angle the pan in such a way that it interfered with the sensor. so, i had to do this:
i had much less problems clearing the sides of the pan, but i figured out why. with the stock pan i had used a gm pan gasket. this time i had a felpro, and it is about twice the thickness. here's how much i had to hammer the stock pan, not just in this location but in 8 spots:
with the felpro i only had to just barely tap down the edge of the scraper, hammer 2 spots on the sides, and then trim the gasket in a couple of places where the rod bolts hit it. here's a pic of the rail on the block so you can see how much it was clearanced for the stroke, and you can also see the 3 new studs i installed to replace the long windage tray studs:
http://home.houston.rr.com/msr/bottom.jpg
i also discovered the dispstick tube didn't seat all the way because it was hitting one of my aftermarket main caps. i cut it down and now it seats. it seems to be reading properly, since 6 quarts (+1 in the filter - it's a big filter) in the pan reads exactly one quart low on the dipstick. i think canton says the pan is full with 7qts, plus however much your filter and engine holds?
i can't think of anything else that might help the next person right now, if i remember i'll add more later.
thanks.
edit: messed up the images
-michael
[Modified by MSR, 10:57 PM 3/4/2004]
