How to remove the shocks?
Old Mar 3, 2004 | 03:12 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default How to remove the shocks?
The bottom is just two bolts, but the top.. when I try to untwist the nut, it just turns the shaft. It doesn't look like there's enough room to get two jam nuts in there.
My goal is to change out my rotted lower shock grommets.
Help. :smash:
(Front shocks, 1985 Z51)
[Modified by CentralCoaster, 12:13 PM 3/3/2004]
Old Mar 3, 2004 | 03:21 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: How to remove the shocks? (CentralCoaster)
The top of the threaded shaft is either a squared off section that will take an open end wrench to hold the shaft or if the shocks are newer, you use an allen wrench in the top of the shaft. I forget what size allen wrench
:seeya
[Modified by jackdaroofer, 3:23 PM 3/3/2004]
Old Mar 3, 2004 | 03:28 PM
CentralCoaster
Default Re: How to remove the shocks? (jackdaroofer)
Awesome. I just picked up and read manual... but I knew The Forum would be faster!
To How to remove the shocks?
