Clutch for LT1
Old Mar 3, 2004 | 04:17 PM
cresus's Avatar
cresus
Default Clutch for LT1
So my throwout bearing is gone and I figured I might as well change the clutch while I have the tranny out. Just curious what people have used to replace the stock one and how they are. I'm currently looking at the RAM clutches (OEM and PowerGrip series) # 88483 and 98483. Also, the parts store Borg Warner is a little cheaper but I'm not sure how it is. Any experience would be useful and appreciated. Thanks.
Old Mar 3, 2004 | 04:40 PM
Aaron71771's Avatar
Aaron71771
Default Re: Clutch for LT1 (cresus)
My 2¢ is the stock Luk clutch is fine for most applications.
Old Mar 3, 2004 | 09:18 PM
bogus's Avatar
bogus
Default Re: Clutch for LT1 (Aaron71771)
they all use the same pressure plate, made by Valao.
RAM and LUK are about equal.
you will want to investigate the flywheel... they cannot be turned, for any number of reasons. and they are EXPENSIVE. you might want to check with the engine shops to see if they have any low mileage take-offs.
Old Mar 3, 2004 | 10:25 PM
cresus's Avatar
cresus
Default Re: Clutch for LT1 (bogus)
The flywheel can't be resurfaced??? I know they can't be turned because that leaves a taper on the flywheel causing runout but if they can't be resurfaced that's gonna change a lot. Please someone tell me there's an option for this.
Old Mar 4, 2004 | 07:41 AM
Aaron71771's Avatar
Aaron71771
If the flywheel has been scratched up, your only option is replacement. A lot of folks go the single mass flywheel route - it's lighter and the engine will rev a little faster.
Old Mar 4, 2004 | 08:22 AM
cresus's Avatar
cresus
If the flywheel is in good condition is it ok to reuse it though? All clutches say flywheel must be resurfaced.
Old Mar 4, 2004 | 08:35 AM
Movnviolation's Avatar
Movnviolation
Just had my zf rebuilt. The shop sent the dual mass flywheel out to be resurfaced, put in new luk clutch & pressure plate. Everything is fine.
I asked them about resurfacing the flywheel and they do it all the time! :steering:
Old Mar 4, 2004 | 08:56 AM
bogus's Avatar
bogus
Default Re: Clutch for LT1 (Movnviolation)
:eek:
here is the scoop - the dual mass does NOT have a taper on it. I asked Bill @ ZFDoc, and he said it is perfectly flat.
There are three reasons why you don't resurface a DM...
1) The two masses are joined by a rubber "spring". That acts much like the springs on a friction disc. That rubber is prone to failure if exposed to oils or cutting fluid.
2) The space tolerances are soooo tight... that to remove .005 off a flywheel effects its placement.
3) the rubber wears out. loses it's elasticity. Once that happens, the DM can start rattling around and it will sound much like a rod knock.
I have no estimates to when that will happen, but it has. Don't expect an original DM to last more than 125k miles or so... it all depends on how you drive it, too.
Going to a single mass flywheel is tricky. SBCs are internally AND externally balanced, so if a single mass is installed, and not balanced right to the engine, you WILL get a nasty vibration. Just be cautious if you decide to go this route.
Old Mar 4, 2004 | 09:47 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
:eek:
:iagree: with Bogus and you dont want that vibration :yesnod: Ask me how I know this :lol:
Old Mar 4, 2004 | 10:05 AM
cresus's Avatar
cresus
Default Re: Clutch for LT1 (VictorRussell'92)
So did you put a SM aluminum flywheel on and have balancing issues? I started looking around for one and the best I found was a Fidanza flywheel for $350. This throwout bearing is getting awfully expensive. I have 105k miles on the car but it sounds like I may have a bad DM flywheel since I have always had a low pitch knock that is not a rod and I never could figure out what it is. Any ideas where one can get a flywheel for cheap that will work without requiring an engine balance. Thanks for the help.
Or should I just change the throwout bearing and hope everything else works for a few years?
Old Mar 4, 2004 | 10:17 AM
bogus's Avatar
bogus
as I stated above, check the engine builders, you might find a deal on a low mileage take-off part (ie, used).
I would replace everything.
Remember, the ZF is prone to making a lot of noise... so try to isolate the noise... if its father back, it's more than likely the gearbox, doing it's thing.
if it's to the front, then I would blame the dual mass. There is a test for it, but I don't remember HOW, I remember what, if the 2 masses deflect more than 1", you MUST replace.
I would get a helms manual, too... and contact Bill at http://www.zfdoc.com. He has a FAQ page, too. Bill is a diety when it comes to these units.
Old Mar 4, 2004 | 11:54 AM
DieL's Avatar
DieL
I put in a centerforce and i love it. Its smoother and lighter than the stock clutch and handles 90% more power- so they say.
I also had my flywheel surfaced without my permission. I got serious vibration at mid rpm and at high rpm and what sounded like rod knock as well at idle when touching the throttle.
Old Mar 4, 2004 | 01:54 PM
bogus's Avatar
bogus
Default Re: Clutch for LT1 (DieL)
some of the noise you got was from the tranny itself... not a surprise, really. the ZF6 is noted for being loud.
To Clutch for LT1
