Which injectors to buy?
Old Mar 3, 2004 | 05:05 PM
HC4-Vette's Avatar
HC4-Vette
Default Which injectors to buy?
8- 28# Bosch injectors for $99
or
8-24# Ford Motorsport injectors for $150
Which one is better?
Old Mar 3, 2004 | 05:08 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: Which injectors to buy? (HC4-Vette)
Heard good things about both. Heard more things about the Ford injectors. :yesnod:
Old Mar 3, 2004 | 05:15 PM
TA's Avatar
TA
Haven't heard many bad things about the Fords (injectors that is :D )
[Modified by TA, 5:15 PM 3/3/2004]
Old Mar 3, 2004 | 06:05 PM
HC4-Vette's Avatar
HC4-Vette
Default Re: Which injectors to buy? (TA)
Are the Bosch good?
What's the max HP for a 24# and 28# injector
Old Mar 3, 2004 | 11:33 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Are the Bosch good?
I do not know the max numbers, but ski_dwn_it and Corkvette ran the Ford injectors in their 406's and Cork ran 10.9's all day. They will be using the same injectors in their new 434's putting out at least 600hp at the crank.
Go with the Ford's perfect fit, and are actually 26# when using gm's terms.
PS - I am using them in my 383 :yesnod:
Old Mar 4, 2004 | 08:09 AM
JackDidley's Avatar
JackDidley
If youbuy the bosch the groove that the retainer goes into will need to be extended. Not a big deal but it takes a little time. :chevy
Old Mar 4, 2004 | 08:39 AM
jmrl98's Avatar
jmrl98
Default Re: Which injectors to buy? (Spankyellow)
You may want to go with the lower # fuel injectors with your set up. Other forum members have had problems with rich conditions caused by too large of injectors (better rich than lean understood). :seeya
Old Mar 4, 2004 | 09:16 AM
Red Tornado's Avatar
Red Tornado
Default Re: Which injectors to buy? (jmrl98)
Get the FMS 24# injectors, and an AFPR, set fuel pressure at about 40-42psi
and you should be a-ok.
Old Mar 4, 2004 | 10:30 AM
FD2BLK's Avatar
FD2BLK
Are the Bosch good?
Yes Bosch are great injectors and the FMS injectors are Bosch injectors as well. I don't know what 28 #s you are looking at but if they are the LS1s you need to make shure they are the Z06 injectors or they are only 26#s. The P/Ns for the 28# LS1s are 0280155931 (Bosch #0-280-155-931) If the P/N is not this then they are the 26 #s like SLP is selling for $99
Old Mar 4, 2004 | 03:22 PM
corvettemaster's Avatar
corvettemaster
Default Re: Which injectors to buy? (84LT1)
are these the one's your talking about? on their site they list them as 25#s http://www.slponline.com/view_produc...RTNUMBER=23051
the price seems cheap. would these be good replacements for the factory injectors?
Old Mar 4, 2004 | 03:32 PM
darkman5001's Avatar
darkman5001
Default Re: Which injectors to buy? (bradvette)
I too am thinking about getting these FMS 24# injectors. My engine is mostly stock right now. I am upgrading throttle body to 52mm in the next two weeks, magnaflow catback, and hooker supercomp headers and all soon too. But I still need to get the car inspected, so lets say I put these FMS 24# injectors in, and get a adjustable fuel pressure regulator, will my car fail emissions because it run too rich, or will in not be very rich?? This is a big concern of mine. I want to upgrade vette, but of course want to drive between upgrades, and I don't want it running and smelling like crap.
:chevy
To Which injectors to buy?
