From: SCMR Rat Pack'r Charter Member..Great Bend KS
Re: Torque type mods compared to horse power type mods? (CFI-EFI)
So far, CFI-EFI's statements are unassailable.
Fact: dynometers measure torque. Horsepower is then calculated. The computer program on the dyno may do the calculating, but horsepower cannot be measured.
Fact: you can have torque without motion. I read someplace (at one time!) that the steam engine develops its maximum torque at zero rpm. Zero rpm = no motion. Isn't that interesting? "A force that tends to produce motion" means it doesn't HAVE to, it just WANTS to.
Yes, torque and horsepower are NOT the same thing, therefore they cannot be 'equal' However, as was pointed out, the values for each CAN be equal (and ARE, at 5252rpm). A dollar is not equal to an orange, but you can have "2" of each. Man measures things in numbers....
Good discussion, guys....informative and friendly. :thumbs:
Larry
code5coupe
:seeya
Re: Torque type mods compared to horse power type mods? (rocco16)
Here is an explanation from a chassis dyno manufacturer on how the inertia dyno measures power: <A HREF="http://www.superflow.com/support/cycledyn-theory.html#Inertia" TARGET="_blank">http://www.superflow.com/support/cycledyn-theory.html#Inertia</a>
Re: Torque type mods compared to horse power type mods? (Kizmo)
Look at the type of autocrossing that you want to compete in (NCCC, SCCA or a local sports car club). What kind of mods can you make within your class or the class you want to run in and still be competitive. You will never use a high reving motor (6500-6800) in a low speed autocross. One of the reasons that the early C4s were so successful autocrossing was due to the torque range and band coupled with their suspension.
Gears are great for drag racing but can be a real PITA in a parking lot. Something in the 3.33 - 3.45 range with a motor that makes good torque from 2400 - 5400 coupled with plenty of seat time should allow you to run most courses in a single gear (2nd or 3rd depending on the course).
