it works but won't shut off after you turn?? if thats the case i believe ya just need to replace the turn signal cancell spring there is a left and right spring cost is like a buck or something... :cheers:
if you look into the small space where the stalk goes into the colum you should see the problem. i think it was the 'left signal that this happens to. the reason is theres a small plastic piece that pushes the signal switch. it usually breaks off. i reached in there with needle nose ans super glued it back on. it worked but not smoothly until i had the column rebuilt. anyhow be warned guys... dont press too hard on that lever or it will break.
