converting from old style opti to new style opti.
Old Mar 6, 2004 | 05:32 AM
93 ragtop's Avatar
93 ragtop
Default converting from old style opti to new style opti.
I have installed a hot cam, cloyes double roller chain set, and the newer style cover on my 93. Can someone tell me where to connect the 2 vacuum lines at? Also, does the new electrical harness have to be repinned? It looks like it will plug in up by the manifold, but it seems to me someone once said it needs a different pin configuration. Course, I could be wrong. Thanks for your help.
Old Mar 6, 2004 | 09:01 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Re: converting from old style opti to new style opti. (93 ragtop)
The larger of the two fittings on the opti is stepped down with a reducer nipple, then runs to a manifold vacuum port. There are a couple of diaphragms inline close to where it hooks into the intake. I believe one reduces the strength of the vacuum signal and the other acts as a check valve. Either way, you'll have to get these, probably from a dealer, and make sure they're installed in the right direction. The other one hooks into the air intake to draw clean air for the system. I believe some people have run this one to inside the car and installed some type of filter to draw the driest air possible. You can also get this harness already made up from the dealer. I have heard there's a difference in the wiring too but don't know since mine's a 95 and so wasn't an issue when I replaced mine. I think there's a tech tip on this conversion as well. Hope this helps.
Old Mar 6, 2004 | 09:58 AM
bogus's Avatar
bogus
Default Re: converting from old style opti to new style opti. (Corvette Kid NC)
Order GM part 12556174 - harness.
one end attaches to the intake, in front of the throttle body, the other, you have to attach to the intake for vacuum. I think the harness is labled for fresh air/vacuum.
there is a wiring difference, but gee, I think that only effects 1992 versions.
Old Mar 6, 2004 | 10:13 AM
cprgmr's Avatar
cprgmr
I assume that you already have the vac harness (P/N 12558921). The GenII opti has two vac connectors (see #2 & #3 in the pic). Attach the line with the gray plastic connector to #2 (rubber end) and the line with the check valve to #3.
Poke a small hole in the air intake duct and put the gray fitting into this hole.
You'll have to tap into a vacuum location on the intake for the other tube. There was a post not too long ago showing a possible location - you can probably find it by doing a search. Just make sure that the check valve is on the end where you tap into the intake.
If you have the wiring harness (P/N 12130319) it should plug right in (according to Jeff K at Superior Chevrolet).
Good luck!
:cheers:
[Modified by cprgmr, 9:14 AM 3/6/2004]
[Modified by cprgmr, 9:15 AM 3/6/2004]
Old Mar 6, 2004 | 11:49 AM
bogus's Avatar
bogus
Default Re: converting from old style opti to new style opti. (cprgmr)
for a touch of clarification, item "1" on the above pic is the coil input.
Old Mar 6, 2004 | 01:01 PM
cprgmr's Avatar
cprgmr
Default Re: converting from old style opti to new style opti. (bogus)
:yesnod:
Old Mar 6, 2004 | 10:21 PM
cprgmr's Avatar
cprgmr
Hey bud - enable your instant messaging in your profile. I have a tip for you that will make this job a lot easier! :cheers:
Old Mar 6, 2004 | 11:56 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Why not post it here for everyone else who is doing the conversion.. ;)
Old Mar 7, 2004 | 05:47 AM
93 ragtop's Avatar
93 ragtop
OK, did that. Sorry I didnt get back to anyone yesterday, I spent 13 hrs. in the garage. The problem with the harness hook up is there is a small piece of plastic in the new one that is used to only allow the plug to go on one way. Well it is made different then the orig. plug. So, what I did was take my dremel tool and grind it out of there. I was concerned about the wiring matching up as well. The colors are different, however the letters are the same. Bottom line, it did work as wired. I still have to tie the vacuum lines in. But I would like to say thanks to everyone for their suggestions and help.
Old Mar 7, 2004 | 11:04 AM
bogus's Avatar
bogus
:cool:
To converting from old style opti to new style opti.
