Z51?
Old Mar 7, 2004 | 12:46 AM
Jloshotz's Avatar
Jloshotz
Default Z51?
My 85 vette is missing the rpo sticker on the inside of the console lid, and I would love to see what rpo's the car came with....How can I tell if it is equipped With the handling package (Z51) asdide from having the sticker? Anyone have any tips?
Thanks All!
Old Mar 7, 2004 | 12:47 AM
bogus's Avatar
bogus
Default Re: Z51? (Jloshotz)
get the code off the spring... it will be either stamped in the spring or on a sticker.
if the code is there, post it here, someone can translate the Z51 spring codes...
the other dead give away - do you pee blood? if so, you got a Z51. :D
Old Mar 7, 2004 | 12:50 AM
Curveit's Avatar
Curveit
Default Re: Z51? (bogus)
:lol: That killed me!!!
:chevy
Old Mar 7, 2004 | 01:30 AM
Gary04Z06's Avatar
Gary04Z06
Default Re: Z51? (Curveit)
Another way to tell is to count the number of turns of the steering wheel. If it's only 2 full turns from lock to lock, that's a sport rack & pinion, or Z51.
2 1/2, or something like that is not a Z51 R&P.
Also if you have 16 x 9.5 in. wheels on all four corners, sway bars, spring rates, oil cooler, shocks, and power steering cooler.
Old Mar 7, 2004 | 01:36 AM
bogus's Avatar
bogus
I just remembered something important... the 1985 RPO sticker is on the lid of the storage bin behind the drivers seat...
check there.
Old Mar 7, 2004 | 01:45 AM
Jloshotz's Avatar
Jloshotz
You guys are the best; thanks for the fast replies and advice...I'll check those two things tomorrow!!
:steering:
Old Mar 7, 2004 | 03:08 AM
okinawa86vette's Avatar
okinawa86vette
Be aware, though, that in '85, you could order a car that had all the Z51 stuff with the base suspension, except with the softer springs and smaller swaybars. My '86 had the oil cooler, bilstein, hvy duty radiator, radiator boost fan, but had the base suspension(originally, it was rebuilt to be completely Z51 from an '85 parts car I had).
Also not that in '85, power steering cooler's weren't available. This came out in '87 from the racing experiences of the earlier C4's.
An easy way to tell is to measure your swaybar. Use a pipe wrench to figure out the diameter. If it' 30mm, its a Z51. Of course, anything anyone's said here goes out the window if someone along the way modified the car.
Chris
Old Mar 7, 2004 | 04:17 AM
vizkiz's Avatar
vizkiz
Threadkiller
Cruise-In 9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09
I thought that was only on 84s?
Old Mar 7, 2004 | 06:17 AM
NoWorries's Avatar
NoWorries
Default Re: Z51? (vizkiz)
What if I don't have a front sway bar? :p:
Quick question, is the auxiliary fan synonomous with Z51 or could you get it seperately?
Old Mar 7, 2004 | 07:50 AM
okinawa86vette
Default Re: Z51? (NoWorries)
The aux fan could be ordered as a sep option. My '86 was equipped like that. All the stuff that came with the Z51 package could be ordered seperate cept for the springs/swaybars/steering rack(Z52's had that rack too when they came out in '87). That and when the pwr steering cooler came out, you couldn't get that sep either.
Chris
Old Mar 7, 2004 | 09:29 AM
screeminmeanie's Avatar
screeminmeanie
I'm not sure about the 85's, but both my 84 Z51's have "Z-51" stamped on the under side of the lower control arm.
Old Mar 7, 2004 | 11:39 AM
vader86's Avatar
vader86
Your sticker should be in the bin behind the drivers seat. It is also on top of the gas tank if you want to go in there and get it.
The control arms and spring have stampings that indicate the suspension option.
Old Mar 7, 2004 | 01:12 PM
Jloshotz's Avatar
Jloshotz
You guys are great; thanks for all the info. I'm gonna look into this stuff later..i'll let you guys know what i came up with
Many Thanks! :chevy
Old Mar 7, 2004 | 07:08 PM
okinawa86vette
Default Re: Z51? (screeminmeanie)
You're right, my '85 parts car had Z51 stamped there too.
Chris
Old Mar 7, 2004 | 10:49 PM
Mark-44's Avatar
Mark-44
:iagree:
If you do have a Z-51 drive it...you'll find the smoothest roads and enjoy it....
They really take the corners great.
Mark
85 Z51
Old Mar 7, 2004 | 10:58 PM
Jloshotz's Avatar
Jloshotz
Default Re: Z51? (Mark-44)
Thanks all, Im gonna check the control arms after the threat of snow dissapates (they're talking snow by me tomorrow :banghead: ) No rpo sticker behind the driver or passenger cargo comartment. A previous owner Turned the compartments into a subwoofer enclosure (nicely done thank god) and dynomatted the whole area, so if there was a sticker in there.....you get the picture. as far as dropping the gas tank to check there, thanks for the advice; not interested...lol. I'll just see how fast she can take the cloverleaf off ramps and judge by that before i drop the tank. Thank you all for your great advice!
Old Mar 8, 2004 | 12:28 AM
okinawa86vette
Another way, but not the cheapest, is to go to http://www.corvettemuseum.com and order a copy of the window sticker or build sheet. You just punch in your VIN and I think it was about 10 or 15 bucks.
Chris
To Z51?
Old Mar 8, 2004 | 03:56 AM
vizkiz's Avatar
vizkiz
Threadkiller
www.corvettemuseum.com/library-archives/build_sheets/index.shtml
:eek: It's $40 now for non-members!
Old Mar 8, 2004 | 05:09 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: (vizkiz)
Easy... You don't even have to get out of the car
Start the car and turn the steering wheel lock to lock.
Z51 wheel will go 2.25 turns lock to lock.
non-Z51 will go 2.5 turns lock to lock.
correct me if I'm wrong guys. :seeya
[Modified by CentralCoaster, 2:12 AM 3/8/2004]
Old Mar 8, 2004 | 08:55 AM
skybolt31's Avatar
skybolt31
Default Re: (CentralCoaster)
I think, but I am not sure, that the Z51 included the Corvette embroidery on the seat headrest. I think I heard someone say that, if true, would be and easy way to tell.
