Electric waterpump question
Old Mar 7, 2004 | 06:10 AM
93 ragtop's Avatar
93 ragtop
Default Electric waterpump question
On hooking up the relay where do you connect the signal wire? I realize this needs to be a terminal in the "on ignition" position. I was thinking the fan relays since one of the wires on it are only hot with the ignition switch in the on position. Any suggestions?
Old Mar 7, 2004 | 08:10 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Re: Electric waterpump question (93 ragtop)
The pink wire(s) in the engine compartment harness that runs along the driver's side. Up towards the front you'll find where the factory spliced them to go to the relays on the side of the radiator. I located my relay near there too and it was an easy hook up. Strick has a good article on the whole installation in tech tips.
Old Mar 7, 2004 | 12:36 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
I used the pink wire to the fans also. :steering:
Old Mar 10, 2004 | 06:53 AM
93 ragtop's Avatar
93 ragtop
Default Re: Electric waterpump question (Ramrod92)
sorry for taking so long to get back on this, but thanks for your suggestions!! That is what I will use.
Old Mar 10, 2004 | 10:02 AM
Strick's Avatar
Strick
Chris and Ransome are correct, it's the pink wire and you can find it on the driver's side engine compartment in the harness running along the fender wall. :thumbs:
To Electric waterpump question
