Roll Bar
Old Mar 7, 2004 | 09:51 AM
GS023's Avatar
GS023
Default Roll Bar
Has anyone installed one of these? How do you like it? Bolt vs weld in?
http://store.yahoo.com/corvetteforum/c4stfrsu.html
:banghead:
Old Mar 7, 2004 | 10:18 AM
CFI-EFI's Avatar
CFI-EFI
Default Re: Roll Bar (GS023)
Why would you want one? It isn't NHRA or SCCA legal. Like the looks???
RACE ON!!!
Old Mar 7, 2004 | 10:25 AM
zrracer's Avatar
zrracer
St. Jude Donor '11, '14
I would get one that is SCCA approved and installed properly so that it would work. I would also consider a crome molly set up. Its lighter. The down side s are numerous. Hard to see looking out rear view mirror. No storage for the top. I had one powder coated which looks nice and replaced the rear carpeting so we could have a OEM look.
Robin
:cheers:
Old Mar 7, 2004 | 11:45 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Dave makes some good products, but in all honesty when it comes to a rollbar/cage, you can't beat a custom fabricator.
Old Mar 7, 2004 | 12:30 PM
BigC4's Avatar
BigC4
Sounds like these would be legal if they were welded in and they look nice. Chrome moly would be nice and on a cage like this it may save 10 lbs, but it is a lot more expensive.
Old Mar 7, 2004 | 11:22 PM
BillWelter's Avatar
BillWelter
If you want a real rollbar, check into the ones made by Autopower. I have one (2") and it's great. The brackets are welded to the frame, and the bar is bolted in. If you're careful making the cuts in the fiberglass witha small cutoff wheel, you can put the fiberglass pieces back in when the bar's not in there. Also, spray foam insulation makes it quiet. When the bar's not in there, the carpet covers up the brackets. Visability out the back is very bad, so be sure to remove the bar, which takes about 15 minutes.
Old Mar 7, 2004 | 11:27 PM
Gary04Z06's Avatar
Gary04Z06
Default Re: Roll Bar (BillWelter)
I've got that one. You can bolt it in or weld it. Great quality and Dave is a great guy to buy from.
PS...that's my car in the pic)
Here are some more pics: http://forums.corvetteforum.com/zerothread?id=636509
From Dave: "Here's a quick summary of the S/T frame. It's constructed of 1.75 x .120 DOM tubing to meet all the latest guidelines. (No you can't store your roof and have a safe unit.) The design was patterned from the SCCA GCR book and should be a legal unit if it is welded in place. As shipped, we supply nutserts with a 14000lb pull out spec to attach it to the frame. As a bolt in unit, it can be removed and new carpet or the original carpet reinstalled and the Dealer will never know you had it in there."
Old Mar 7, 2004 | 11:28 PM
Gary04Z06's Avatar
Gary04Z06
Default Re: Roll Bar (CFI-EFI)
RACE ON!!!
It is legal if it's welded in.
Old Mar 8, 2004 | 06:58 AM
GS023's Avatar
GS023
I like the idea of the bolt in with welded brackets. Did the unit from Autopower come set up that way?
Joe
:chevy
Old Mar 8, 2004 | 01:06 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Roll Bar (Gary96LT4)
RACE ON!!!
SCCA, probably. I simply went by the ad:
this frame is not approved by the SCCA to be used as a roll bar because it is not welded directly to the car's frame, it utilizes customer installed "Nutserts" to make it a bolt on installation.
NHRA isn't mentioned anywhere. Does it include at least one, front, side bar?
RACE ON!!!
[Modified by CFI-EFI, 11:12 AM 3/8/2004]
Old Mar 8, 2004 | 01:28 PM
ncider's Avatar
ncider
Doesn't it need forward bars to be legal?
Old Mar 8, 2004 | 01:50 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Roll Bar (ncider)
At least one, for NHRA. On the drivers side. That is the 5th point in their 5 point requirement. The photo in the ad is such, that one can't tell if it includes any front side bars, or not. Again, the ad makes no mention of NHRA.
RACE ON!!!
Old Mar 8, 2004 | 02:55 PM
BowTieBlood's Avatar
BowTieBlood
Where can you buy one that's NHRA legal without having to have it custom fabricated? (95 C4) I always liked the looks of the Doug Rippie bar, but guess that's pretty much the same category as this one. What kind of 1/4 times do you have to push to need something beyond the bar shown here? What are the requirements for a car running, let's say, MAX of high 10s?
Old Mar 8, 2004 | 03:07 PM
Gary04Z06's Avatar
Gary04Z06
Default Re: Roll Bar (BowTieBlood)
Dave (R-D Racing) will be offering the 5th forward bar for the drivers side shortly, as an additional option, I believe.
I believe it is needed to be NHRA compliant, but I am not real familer with NHRA rules.
I think he just says its not SCCA legal because he is saying to bolt it in, for liability reasons. That's why its called an S/T Frame Support, not a roll bar. To many legal issues in that area.
But if you weld it, it should pass SCCA tech.
[Modified by Gary96LT4, 6:11 PM 3/8/2004]
Old Mar 8, 2004 | 07:04 PM
CFI-EFI's Avatar
CFI-EFI
Gary96LT4,
Dave (R-D Racing) will be offering the 5th forward bar for the drivers side in the shortly, as an additional option, I believe.
I believe it is needed to be HHRA compliant, but I am not real familiar with NHRA rules.
Who is HHRA? NHRA requires ANY bar to be a 5 point. The main hoop (2 points), two rear diagonals (points 3 & 4), and at least one forward diagonal side bar, outside of the driver (#5).
The bar pictured, assuming it is lacking the forward side bar, is NO bar, in NHRA's eyes. A coupe needs a 5 point roll bar, once it goes quicker than 12.00. IF the firewall and floor are unaltered, that bar is sufficient down to 10.00, or 135 mph, which ever comes first. A convertible, without a hardtop, needs a bar at 13.99. In a convertible, at 10.99, and in a coupe at 9.99, an 8 point roll CAGE becomes mandatory. This is just a quick synopsis of the requirements. Any time a bar is required, so is a 5 point harness. There are other rules, too. That'll get you thinking.
RACE ON!!!
[Modified by CFI-EFI, 5:09 PM 3/8/2004]
Old Mar 8, 2004 | 07:10 PM
Gary04Z06's Avatar
Gary04Z06
Who is HHRA? NHRA requires ANY bar to be a 5 point. Any time a bar is required, so is a 5 point harness. There are other rules, too. That'll get you thinking.
RACE ON!!!
HHRA.....NHRA samething, can't a guy make a type-o?:lol:
Thats for the info on NHRA, and yes, a 5-point harness would be needed, I use one for autox. It really made my times faster. I don't think people realize how much you slide around in the seat until you don't.
Old Mar 8, 2004 | 08:12 PM
CFI-EFI's Avatar
CFI-EFI
I'm the KING of typos. The way the sentence was structured, I thought you referring to one, as opposed to the other. Because of that I thought you might have been referring to IHRA. It was a serious question, because I figured there may be someone in the "game" I wasn't familiar with.
I can see how the harness would help in the twisties. For us "straight liners", it just makes it harder to reach controls. When (if) I get there, I'm going to have to move some of my switches.
RACE ON!!!
To Roll Bar
Old Mar 8, 2004 | 08:27 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Here is what an NHRA bar in a C4 looks like.
http://www.corvettechallenge.info/im...ackeybar1.html
Old Mar 8, 2004 | 09:49 PM
BigC4's Avatar
BigC4
Default Re: Roll Bar (mackeyred96)
So, for a roll bar to be legal for NHRA it needs to be a 5 point, but the fifth bar does not have to be welded in?
Old Mar 9, 2004 | 12:07 AM
RonRed89's Avatar
RonRed89
John,
That is just too nice! What a terrific job they did on your car. I may have to send my car to these guys for the same treatment someday.
Is the curve in those rear points an issue at all from a rules standpoint?
Ron
