Fuel pump gasket
Old Mar 7, 2004 | 03:25 PM
Bruce's Avatar
Bruce
Default Sending unit gasket
I just finishing up pulling my sending unit am in the process of installing a twin in tank 255lph fuel pump with 2 feed lines in my car. I noticed a the sending unit gasket are kinda rusty, so i just clean it up a little.
My question is should the gasket be replace? is that a dealer part? or any auto parts store? Thanks guys
Bruce
[Modified by Bruce, 2:27 PM 3/7/2004]
Old Mar 7, 2004 | 06:40 PM
Bruce's Avatar
Bruce
Default Re: Sending unit gasket (Bruce)
No one??? I know many of you has pulled out your sending unit before to install a new pump ect.
Old Mar 7, 2004 | 06:51 PM
CFI-EFI's Avatar
CFI-EFI
I have changed pumps in my car, several times. I have never needed to change the gasket. Also, like many, you failed to mention what year you're working on. 1984 - 1989 uses 14076189. 1990 takes 10140598. I doubt that last number is for one year only, but my parts book quits at 1990.
RACE ON!!!
Old Mar 7, 2004 | 06:57 PM
Bruce's Avatar
Bruce
Default Re: Sending unit gasket (CFI-EFI)
Hey thanks for your input. :thumbs: Mine is 93LT1
Bruce
Old Mar 7, 2004 | 09:20 PM
HWoods's Avatar
HWoods
May issue of Vette has an article on replacing C4 fuel pump. I guess if you reuse the gasket and don't smell fuel afterward you got by, I think a new gasket is cheap insurance. good luck
Old Mar 8, 2004 | 06:05 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
When i replaced my pump, the kit came with some large orings that weren't even the right parts. It didn't come with the gasket, but i didn't replace it anyways. It's probably cork and a pain to chisel off without getting it in the tank. If I were you, I'd just put some gas-proof RTV on it if there is any, maybe "the right stuff" or maybe copper rtv.
Old Mar 9, 2004 | 12:03 PM
sraft's Avatar
sraft
Default Re: Sending unit gasket (CentralCoaster)
When I did some work on my '94 last spring my gasket was permanently compressed/deformed and rusty. Instead of taking chances I got a new one from the Chevy dealer.
To Fuel pump gasket
