Standard vs Roller block pics
Old Mar 7, 2004 | 05:31 PM
-js-'s Avatar
-js-
Default Standard vs Roller block pics
Hope this helps some of you wondering if you can put a factory roller cam into a 1986 block.
a roller block
a non roller block from an 86 al head motor
Old Mar 7, 2004 | 08:14 PM
zelement's Avatar
zelement
Default Re: Standard vs Roller block pics (-js-)
You can still use a roller cam in a non roller block. You just have to use retrofit lifters.
That's what I did.
Old Mar 8, 2004 | 06:07 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Thanks for the pics. :cheers: Those retrofit lifters are $$$$. So, to machine the block, it looks like it involves welding bosses on there, not just drilling and tapping.
Old Mar 8, 2004 | 06:21 PM
-js-'s Avatar
-js-
Default Re: Standard vs Roller block pics (CentralCoaster)
Yes, The lifter bosses top surface and the casting area next to them is also different.
Old Mar 8, 2004 | 10:16 PM
Curveit's Avatar
Curveit
:thumbs: Thanks for the pics....I've heard some late '86 blocks had the bosses, but weren't tapped. So I guess you'd open it up and see. Looks like you'd still have to grind "shoulders" behind the lifters either way.
:chevy
To Standard vs Roller block pics
