Headers that bolt up to cat-back
Old Mar 8, 2004 | 09:34 AM
kawboy5792's Avatar
kawboy5792
Default Headers that bolt up to cat-back
Does anyone make [long tube] headers that easily bolt up to a cat back (in my case B&B) exhaust systems? Thanks for the help.
Old Mar 8, 2004 | 11:06 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Headers that bolt up to cat-back (kawboy5792)
TPIS makes headers for LT1 which bolt up to the resonator which, in turn, bolts up the cat-back.
Old Mar 8, 2004 | 11:35 AM
STL94LT1's Avatar
STL94LT1
I had a muffler shop alter my Flowmaster cat-back to work with the EM longtubes and Dynatech PowerCats. The longtubes fit closer together than the factory manifolds/cats.
Old Mar 8, 2004 | 11:53 AM
Strick's Avatar
Strick
The answer is NO. You have to fabricate, but it's easily done at the muffler shop.
Old Mar 8, 2004 | 01:02 PM
PBnf's Avatar
PBnf
Doesn't the term cat-back infer that a cat is in between the two systems? If that's the case wouldn't the headers have to connect to the cat which in turn connect to the cat-back exhaust? :confused:
Old Mar 8, 2004 | 10:50 PM
kawboy5792's Avatar
kawboy5792
Default Re: Headers that bolt up to cat-back (PBnf)
Yes, if you want to be that technical about it, it does. but the fact is, i currently have a cat-back exhaust system installed, and i was wondering if, after removing the cats and adding headers, any headers would bolt up to the (formerly) cat-back exhaust. i guess it would make the exhaust a collector-back exhaust in this situation. :thumbs:
Old Mar 9, 2004 | 09:25 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Yes, they did make them. They were DRM long tube stainless headers and they bolted up to the factory exhaust,(by passing the cats), Flowmaster ,B&B etc. I have them on my car (93 ), but the guy who made them for DRM retired, Watson was his name I believe, and the patent went with him. Maybe DRM can find you a used set.
Old Mar 9, 2004 | 08:46 PM
kawboy5792's Avatar
kawboy5792
Default Re: Headers that bolt up to cat-back (steve40th)
Thanks! Ill check into it. Othewise, do most people just fab up a 3" pipe to connect the collector and the exhaust?
To Headers that bolt up to cat-back
