The best roller rockers?
Old Mar 9, 2004 | 12:40 AM
Epyon127's Avatar
Epyon127
Default The best roller rockers?
Which ones are the best?
I thought that the Comp Cams Pro-Magnums were but now I saw the Comp Cams High-Tech ones that are more expensive and billed as better?
They also come in bigger ratios.
What is the best set. (Not restricted to the examples)
Old Mar 9, 2004 | 09:11 AM
LT4BUD's Avatar
LT4BUD
Default Re: The best roller rockers? (Epyon127)
Looks like the hi-tech is not suitable for street applications????
http://www.compcams.com/Technical/Ca...3/HTML/280.asp
I really don't know, just looked at the above webpage
:confused:
Old Mar 9, 2004 | 11:45 AM
C10 JDR's Avatar
C10 JDR
Default Re: The best roller rockers? (LT4BUD)
That page is lifters, not rockers :confused:
Old Mar 9, 2004 | 02:31 PM
LT4BUD's Avatar
LT4BUD
Default Re: The best roller rockers? (britvette)
:_dupe:
oops!!!!
Old Mar 10, 2004 | 10:58 AM
jburnett's Avatar
jburnett
T&D or Jesel... Hey... You asked... For conventional stud mounted rockers it's hard to go wrong with either Comp's Pro Magnums or Crane's Gold Race...
-Jeb
Old Mar 10, 2004 | 02:05 PM
JAKE's Avatar
JAKE
CompCams has been running an ad showing a broken Crane Gold Rocker.
I don't remember the ad saying what were the conditions causing the failure, but I suspect it was heavy spring pressure coupled with lots of R's.
I use to run Crane's Gold rockers with 240# on the seat and close to 700# open shifting at 82 and never had a failure though.
Jake
To The best roller rockers?
