dash light...
Old Mar 9, 2004 | 08:58 AM
89blkvet's Avatar
89blkvet
Default dash light...
I have the LED dash on my 89. The fight side (eng temp, gas mileage) is now not as bright as the rest of the dash lights. I can still see it, but barely. Now if a light goes out, doesn't it completly go out.....why would it dim and how difficult to change out? Thanks
Old Mar 9, 2004 | 10:07 AM
rick lambert's Avatar
rick lambert
Default Re: dash light... (89blkvet)
I had the same problem twice, both time it was a burned out bulb, if it happens again I'm replacing sockets. I was new to C4's when this happened and hadn't joined the forum yet-so I pulled the whole cluster to replace the bulbs :nono: found out later on the forum you don't need to pull the cluster,
Good Luck :seeya
Old Mar 9, 2004 | 11:37 AM
89blkvet's Avatar
89blkvet
Default Re: dash light... (rick lambert)
So how would I get to that light without pulling the cluster?? Thanks
Old Mar 9, 2004 | 11:53 AM
skybolt31's Avatar
skybolt31
Remove the bezel, there will be 4 tin covers over the bulbs, they are just pushed into place, so pry the ones off over the failed bulb(s) and the bulb can be removed with needle nose pliers, just pull them straight out. New bulbs can be slid in the same way and reassemble. Find out what kind of bulb you need first and get at least on of them. In some areas, the bulbs are becoming scarce.
Old Mar 9, 2004 | 12:01 PM
rick lambert
Default Re: dash light... (skybolt31)
That's right, but when installing your new bulbs use a piece of shrink tape or something to prevent touching them, body oils can reduce the life, if not shorten it of the bulbs.Look on the help section there may even be a post. ;)
Old Mar 9, 2004 | 02:05 PM
89blkvet's Avatar
89blkvet
Excellent !! I will give that a shot this weekend. THANKS
Old Mar 9, 2004 | 02:16 PM
emsrescu's Avatar
emsrescu
mine don't work and the bulbs are good. I was wondering if i could just take them out and put in normal sockets and bulbs. Has anyone done this?
Old Mar 9, 2004 | 03:44 PM
brookman's Avatar
brookman
Default Re: dash light... (emsrescu)
CHeck this link
http://www.corvettemagazine.com/1999...ash/dashp1.asp
Old Mar 10, 2004 | 08:43 AM
emsrescu's Avatar
emsrescu
Default Re: dash light... (brookman)
turns out they lost the ground. now she works great. :D
To dash light...
