Help With Tire Size
Old Mar 9, 2004 | 10:52 AM
MostWanted's Avatar
MostWanted
Default Help With Tire Size
I am purchasing new tires for my 1996 LT1. They are the new Cooper Zeon 2XS. I am getting all 4 for $635 mounted and balanced. The front tires of course are 255/45-17 and the rears are supposed to be 285/40-17. The only problem is that Cooper only makes a 275/40-17. Will this be a problem? The tire dealer says the only difference is the width of the tire is about 1/4 of an inch less. Thanks for your help.
[Modified by TorchRedXCVI, 9:53 AM 3/9/2004]
[Modified by TorchRedXCVI, 9:58 AM 3/9/2004]
Old Mar 9, 2004 | 11:09 AM
Gary04Z06's Avatar
Gary04Z06
Default Re: Help With Tire Size (TorchRedXCVI)
No problem. My '96 Z51 has the 275s on all four from the factory. I'd just put those on all four, (maybe not if you have 8.5" wide front rims) you'll be able to rotate and maybe handle a little better.
Old Mar 9, 2004 | 11:20 AM
MostWanted's Avatar
MostWanted
Default Re: Help With Tire Size (Gary96LT4)
Thanks for the info! Yeah, I have the 8.5's on the front so I wouldn't be able to rotate anyway. One more question though. Should I take the sensors off of the rims since I will not have the run flat tires? Thanks again!
Old Mar 9, 2004 | 11:29 AM
Gary04Z06's Avatar
Gary04Z06
I would take the sensors out, the dash light will come on, but you can pull the bulb out.
Old Mar 9, 2004 | 11:38 AM
MostWanted's Avatar
MostWanted
Thanks again Gary! I have pulled the fuse to that bulb since my cruise control is out of commission anyway. Thanks!!
Old Mar 9, 2004 | 11:54 AM
Perfusion's Avatar
Perfusion
:iagree: Pulling the bulb is a very easy way to go...
Old Mar 10, 2004 | 07:03 PM
Rick Williams's Avatar
Rick Williams
I recently put he exact Cooper tires on my 87, with 94 wheels..
I was able to get mine wholesale, and I am very satisfied with them, Only put 1,000 miles on them so far..
stay safe
Old Mar 11, 2004 | 02:19 PM
MostWanted's Avatar
MostWanted
Default Re: Help With Tire Size (Rick Williams)
I got them put on two days ago. They look great and make the ride a whole lot better. Thanks for all the advice guys! :flag
To Help With Tire Size
