700R4 trans help needed
Old Mar 9, 2004 | 12:32 PM
Graybeard's Avatar
Graybeard
5th Gear
Default 700R4 trans help needed
My '90 had a minor ocassional shudder when shifting into OD. A "friend" said it was in need of a TV cable adjustment which he did. For free. I sure got my money's worth. Now I have serious trouble. I getting bad slippage in 3rd and OD. I made it home in 2nd gear. The car still shifts in and out of 1st and reverse solidly. The 1-2 shift still seems fine. 2nd gear still seems solid. I know the clutchs must've taken in on the chin getting me home, but if they were finished, I assume I'd lose all 4 gears, or they'd at least be weak. I checked the oil, and yes, it smells fried. I picked up a filter and pan gasket set along with cherry juice, but before i crawl in the dirt, I have some questions.
Is there a "right" way to adjust the TV cable?
Is a trip to Aamco transmissions for a "power-flush" worth the time?
Am I screwed and now need a trans overhaul?
OK, I realize the last question is silly and there's no way to diagnose the problem without seeing the car (I own a custom Harley shop). But I'm a bike guy and have limited knowlege with cars. Hoping y'all can bail me outa this...
Old Mar 9, 2004 | 12:56 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: 700R4 trans help needed (Graybeard)
1.) Is there a "right" way to adjust the TV cable?
2.) Is a trip to Aamco transmissions for a "power-flush" worth the time?
3.) Am I screwed and now need a trans overhaul?
1.) Yes.
2.) Too late.
3.) Yes.
Not a silly question. You can save some time and money, if you skip 1 and 2, at this point, and jump right to #3. Do you have a trans guy, you know and trust? Let him test drive it. Past experience verifies my diagnoses. Get a second opinion, then schedule the "surgery".
RACE ON!!!
Old Mar 10, 2004 | 12:57 AM
Blue85L98's Avatar
Blue85L98
Cruise-In III Veteran
Default Re: 700R4 trans help needed (CFI-EFI)
:iagree: ...
...I learned this from experience...I also lost third gear.
...this also forced me to learn how to rebuild my '85s 700R4.
Old Mar 10, 2004 | 01:19 AM
Midnight89's Avatar
Midnight89
Default Re: 700R4 trans help needed (Blue85L98)
:iagree: Same just happened with my '89. Looks like we can chalk up another 700R4 for the wonderful transmission graveyard in the sky!!
Old Mar 10, 2004 | 01:33 AM
GhosTRydeR_92's Avatar
GhosTRydeR_92
Default Re: 700R4 trans help needed (Midnight89)
your first and second gear is on what they call band. but the 3rd and od run on clutchs if the tv cable is not adjusted right it will burn the clutchs up in no time depending on your driving habits .. have it rebuilt ASAP if not you will begin to damage hard parts in the tranny.. like forward spraggs and so on ! good luck !!! :thumbs:
Old Mar 10, 2004 | 09:22 AM
Flame Red's Avatar
Flame Red
Lost 3rd gear on my 700R4. Got a rebuild and now I am fighting speedo gears that get torn up all the time.
Old Mar 10, 2004 | 04:14 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
:iagree: It's time for a rebuild. :(
I went through the same scenario last year. I had to drive 15miles to get home and then another 10 miles to the trans shop all in 2nd. :crazy:
Old Mar 10, 2004 | 11:13 PM
Dixie91's Avatar
Dixie91
My 91 had the same problem. I went through all the preliminary checks i.e., throttle valve cable adjustment, new fliud and filter, flushed everything, checked the governor and shift valves. None of this worked. I finally broke down, bought and installed a new 700R4 made by Performance Transmission out of Louisanna. Have not looked back since. :cheers:
Old Mar 10, 2004 | 11:24 PM
ROME's Avatar
ROME
I plopped down close to 3K for the most bulletproof 700R4 I could find about a year ago. If this one goes south anytime soon, I'm going directly for a 6-speed swap. There's that old saying that "you can't polish a turd". :lol: Some people praise the 700R4, but probably twice as many folks berate it as a weakly engineered piece of machinery. I figured I'd try to find out first hand rather than rely on the widely varying opinions I've heard.
I do know that there are certain techniques (such as downshifting at high rpm) that should never be practiced with the 700R4. That's how I blew the last one.
Old Mar 15, 2004 | 02:42 PM
Probuilt's Avatar
Probuilt
Default Re: 700R4 trans help needed (ROME)
The 3-4 clutch pack is the major weak point in these units, as you've just seen. There are a few things that can be done to improve this transmission immensely. If you have any questions, let me know?
Old Mar 15, 2004 | 08:51 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: 700R4 trans help needed (Probuilt)
I know I would like to know.... My 3rd gear started going out last year. it's still bad but I can't swing a transplant yet so I'm going to run it till it's dead.
To 700R4 trans help needed
