Getting ready to pull my radiator and give it a good cleaning....was wondering if regular DexCool Anti Freeze was OK going back in my 93 LT1. Also going to do the Throttle Body bypass while its drained. Thanks
The rule of thumb is to put back the same kind you take out since the two don't play well together. Don't mix them. If you have the green, stick with it. If you have the orange (DexCool) then a previous owner must have changed over since it wasn't a factory fill in Corvettes untill (don't quote me here) 95.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Re: Anti Freeze (sundbergjc)
We change customers' trucks one to the other, both ways all the time, according to their preference. I've never seen or heard of any problems resulting from it.
